Nvidia-smi cannot communicate with the GPU (RTX 3060 Ti, Ubuntu 22.04, Kernel 6.5.0-28-generic, Driver 550)
Although I have installed the driver and confirmed that the GPU is detected, running nvidia-smi still results in a failure to communicate with the GPU (I’m working on a server that I access via SSH (using Tailscale)).
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3060 Ti Lite Hash Rate] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
lsmod | grep nvidia (Sometimes it works, sometimes it doesn’t.)
b..@b..:~$ lsmod | grep nvidia
libkmod: ERROR ../libkmod/libkmod-module.c:1941 kmod_module_get_holders: could not open ‘/sys/module/nvidia/holders’: No such file or directory
nvidia -2 -2
dkms status
nvidia/550.144.03, 6.5.0-28-generic, x86_64: installed
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Previously, I also tried with kernel 6.8, but the result was the same. I’ve also tested with multiple driver versions.
What should I do next?
Hi @maidinhtuandat , thanks for reporting this issue.
Could you please attach a bug report when you see this. To take a bug report, you can run sudo nvidia-bug-report.sh in a terminal, and the nvidia-bug-report.log.gz file will be created in the current working directory.
