NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running
nvidia-bug-report.log.gz (136.6 KB)
System spec:
uname -r
5.19.0-1010-nvidia-lowlatency
Ubuntu22.04
GPU Nvidia A10G
nvidia-driver version: 565
I’ve tried install driver from Download The Latest Official NVIDIA Drivers and tried different drivers, nothing worked…
Hello @flimka134, welcome to the NVIDIA developer forums.
I recommend a fresh installation of the system, as I suspect that your driver/kernel version setup will be a bit inconsistent, if you “tried” different drivers without cleaning up properly in between. You said you have 565 installed? Well, then you have residual data from (at least) two other drivers:
Jan 21 08:19:29 ai kernel: [305933.196185] NVRM: API mismatch: the client has the version 550.144.03, but
Jan 21 08:19:29 ai kernel: [305933.196185] NVRM: this kernel module has the version 530.41.03.  Please
Jan 21 08:19:29 ai kernel: [305933.196185] NVRM: make sure that this kernel module and all NVIDIA driver
Jan 21 08:19:29 ai kernel: [305933.196185] NVRM: components have the same version.
