I tried to install the nvidia drivers on a recent installation, under debian 12, but when I run nvidia-smi I get the message: No devices were found.
However, when I look at the PCI attachments :
sudo lshw -C display
*-display
description: 3D controller
product: GP107M [GeForce GTX 1050 Mobile]
vendor: NVIDIA Corporation
physical id: 10
bus info: pci@0000:06:10.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: iomemory:38380-3837f iomemory:38380-3837f irq:21 memory:81000000-81ffffff memory:383800000000-38380fffffff memory:383810000000-383811ffffff ioport:7000(size=128) memory:82080000-820fffff
I installed the drivers following the instructions available on the debian site (cf. NvidiaGraphicsDrivers - Debian Wiki)
Here is some information that may be useful for debugging:
lsmod | grep nvidia
nvidia_drm 73728 0
nvidia_uvm 1380352 0
nvidia_modeset 1249280 1 nvidia_drm
drm_kms_helper 208896 5 bochs,drm_vram_helper,nvidia_drm
video 65536 1 nvidia_modeset
nvidia 56410112 2 nvidia_uvm,nvidia_modeset
drm 614400 8 drm_kms_helper,bochs,drm_vram_helper,nvidia,drm_ttm_helper,nvidia_drm,ttm
sudo dmesg | grep -i nvidia
[ 8.371294] nvidia: loading out-of-tree module taints kernel.
[ 8.373780] nvidia: module license 'NVIDIA' taints kernel.
[ 8.417835] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 8.544325] nvidia-nvlink: Nvlink Core is being initialized, major device number 244
[ 8.546612] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.147.05 Wed Oct 25 20:27:35 UTC 2023
[ 10.060957] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 525.147.05 Wed Oct 25 20:21:31 UTC 2023
[ 10.406873] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 10.453161] nvidia-uvm: Loaded the UVM driver, major device number 240.
[ 10.803586] [drm] [nvidia-drm] [GPU ID 0x00000610] Loading driver
[ 10.803591] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:06:10.0 on minor 1
[ 12.043395] audit: type=1400 audit(1717422553.472:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=534 comm="apparmor_parser"
[ 12.046154] audit: type=1400 audit(1717422553.472:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=534 comm="apparmor_parser"
nvidia-bug-report.log.gz (65.7 KB)
