ac922
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
dnf list nvidia-driver
Updating Subscription Management repositories.
Last metadata expiration check: 3:01:08 ago on Fri 22 Dec 2023 05:50:51 AM -03.
Installed Packages
nvidia-driver.ppc64le 3:535.129.03-1.el8 @cuda-rhel8-ppc64le
follow the instructions carefully in the CUDA linux install guide. Note the sections especially where there are power9-specific setup instructions such as here.
I’m not suggesting that is the only relevant section. Start at the beginning of the guide, read the entire guide, and follow the instructions carefully.
I’ve hit what I believe to be a similar issue (but on CentOS Stream 8) which is documented at: Nvidia driver (545.23.08) core dump on CentOS 8 Stream ppc64le - #3 by samu_gabor
Not sure if this is because I’m on Stream rather than RHEL 8. I’ve provided as much information as I could collect in the above.
