Nvidia-smi shows "No devices were found" on ubuntu server 22.04 LTS with RTX3060
Hello.
I’ve tried many ways to install the driver of RTX3060 on the ubuntu server 22.04 LTS (Actually a dual OS computer with Windows 10), and met some troubles.
At first, I tried to install it with the recommented version from the default source of ubuntu, however when run “nvidia-smi” it shows “No devices were found”;
Secondly, I tried to uninstall (with apt uninstall) and reinstall it with the .run file from nvidia’s official website, and it returns “lib/driver version are not match” when run “nvidia-smi”.
Thirdly, considering about maybe I had not uninstalled the previous driver completely, I tried uninstall it deeply (with “sudo apt purge nvidia-*” and autoremove) and reinstall it again (with .run file), but it was still not work.
Fourthly, I tried reinstall it with PPA source, and “No devices were found” again.
Fifthly, which is the latest attempt, I redownloaded the .run file (NVIDIA-Linux-x86_64-550.67.run) with the latest version and installed it, still with “No devices were found”.
The order above may have some mistakes because of too many attempts, however, I indeed tried the above ways. And here are other informations maybe helpful:
~$ uname -a
Linux agiserver 5.15.0-97-generic #107-Ubuntu SMP Wed Feb 7 13:26:48 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
~$ lspci | grep -i nvidia
03:00.0 VGA compatible controller: NVIDIA Corporation GA106M [GeForce RTX 3060 Mobile / Max-Q] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GA106 High Definition Audio Controller (rev a1)
~$ cat /proc/driver/nvidia/version
NVRM version: NVIDIA UNIX x86_64 Kernel Module  550.67  Tue Mar 12 23:54:15 UTC 2024
GCC version:  gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)
Here is the bug report file:
nvidia-bug-report.log (724.4 KB)
I also find nvidia-installer.log
nvidia-installer.log (41.7 KB)
, nvidia-uninstall.log
nvidia-uninstall.log (1.3 KB)
and cuda-installer.log
cuda-installer.log (180 Bytes)
(I tried to install cuda after the first or second attempt of driver installation, but it had been uninstalled before the next attempt).
I wonder how to make it work well?
I’m appreciate for anyone’s generous help.
RmInitAdapter failed! (0x26:0x56:1598)
Shouldn’t happen, the nvidia driver doesn’t like your bios. For a workaround, please switch to the nvidia-open driver.
