Hi, I’m on Ubuntu 64bits 16.04 and I have a GeForce GTX 750 Ti with driver version 367.35. I’m able to compile the examples and then when I run the NvDecodeGl example it only says:
~/workspace/cuda/Video_Codec_SDK_7.0.1/Samples/NvDecodeGL$ ./NvDecodeGL
[NVDECODE/OpenGL Video Decoder]
Command Line Arguments:
argv[0] = ./NvDecodeGL
[NVDecodeGL]: input file: [../common/video/plush1_720p_10s.m2v]
(and nothing else happens)
More info on the hardware/software using nvidia-smi:
~/workspace/cuda/Video_Codec_SDK_7.0.1/Samples/NvDecodeGL$ nvidia-smi
Fri Aug 12 21:04:23 2016
| NVIDIA-SMI 367.35 Driver Version: 367.35 |
| 0 GeForce GTX 750 Ti Off | 0000:01:00.0 Off | N/A |
| 30% 34C P8 1W / 38W | 258MiB / 2000MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1221 G /usr/lib/xorg/Xorg 184MiB |
| 0 1943 G /usr/bin/krunner 25MiB |
| 0 1967 G /usr/bin/plasmashell 74MiB |
| 0 17005 G /usr/lib/firefox/firefox 1MiB |
I run the nvcc command successfully on folder Video_Codec_SDK_7.0.1/Samples/NvDecodeGL. Then I renamed NV12ToARGB_drvapi.ptx to NV12ToARGB_drvapi_x64.ptx. Further, I copied it to the data/ folder as there already was a file with that name there so I replaced it with the new one.
But the same thing still happens when I execute ./NvDecodeGL
I’m having exactly the same problem. And my ptx is already named NV12ToARGB_drvapi_x64.ptx, so I’m guessing they fixed that in the meanwhile. Very strange that with all their error checking it somehow still ends up in an infinite loop of nothingness. Kind of erodes my confidence in NVDEC…
What are you trying to do? Unless you’ve got a really good reason to be working with nvdecode directly, you’re better off using ffmpeg’s cuvid decoder, and being able to use ffmpeg for all the other stuff like loading and demuxing.
Trying to render a bunch of videos simultaneously. FFMPEG (or libav) would be great, except even if they decode on the GPU, they copy it back to CPU RAM before you can access it, which creates a bottleneck if all you want to do with the movie is display it (better to leave it in GPU memory).
However, I also found the solution to NvDecodeGL not working: just use cudaDecodeGL from the CUDA Toolkit instead, it works perfectly, and demonstrates the same thing.
I am also having the same problem as Findeton and elalish. Since I haven’t been able to find an explanation as to why the cuvidCreateVideoSource is hanging (or how to properly handle the problem), I am checking here again. Anyone able to help?
To make the decoder code sample work, you need to compile the NvDecodeGL with nvcc. NVidia should change their makefile. It is definitely not obvious that this needs to be done!!!
