Running NVDecoder from Docker
I have an application that runs NVDecoder on Ubuntu 22.04 based on the VideoProcessingFramework sample code.
It runs properly on the machine but fails when running inside Docker Container running on the same machine.
I get an error:
“NvDecoder : cuvidCreateVideoParser(&_parser, &videoParserParameters) returned error -97731136”.
I need help to understand why cuvidCreateVideoParser fails.
Thanks,
Rotem Tzuk, Track160
  • Docker command line:
docker run --privileged --runtime=nvidia --interactive --tty --rm --net host --env=“DISPLAY” --env NVIDIA_VISIBLE_DEVICES=all --env NVIDIA_DRIVER_CAPABILITIES=video,compute,utility,display --add-host=host.docker.internal:host-gateway --env CMD=“/appl/bin/exec_video_codec” --env PARAMS=“-i /cases/Case176/Left1.MP4 -g -v” -v /media/disk2/dvlp/Cases:/cases track160-run
exec_video_codec is my app.
Environment:
  • Ubuntu 22.04
  • GPU: NVIDIA GeForce GTX 1080 Ti
  • nvidia-docker --version
    Docker version 20.10.23, build 7155243
  • Video Codec SDK 12.0.16
  • Docker & nvidia-smi output from within the Docker:
== CUDA ==
CUDA Version 11.7.1
Container image Copyright (c) 2016-2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
A copy of this license is made available in this container at /NGC-DL-CONTAINER-LICENSE for your convenience.
mkdir: created directory '/root/.cache'
mkdir: created directory '/root/.cache/xdgr'
Tue Jun 13 12:07:23 2023
| NVIDIA-SMI 525.105.17   Driver Version: 525.105.17   CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  Off  | 00000000:01:00.0  On |                  N/A |
|  0%   40C    P8    18W / 250W |    926MiB / 11264MiB |     16%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
GPU in use: NVIDIA GeForce GTX 1080 Ti
Hello @rotem1 and welcome to the NVIDIA developer forums.
I took the liberty of enabling pretty-print for the console output above.
if you check that output you will see the initial CUDA version of the docker image, which is CUDA Version 11.7.1, while the nvidia-smicommand shows CUDA Version: 12.0.
You should make sure to have the same environments installed since the docker image will use the system installed GPU driver.
I hope that helps.
Thank you @MarkusHoHo
Indeed CUDA version is 11.7.
However this combination works fine when running on the host machine and fails when running inside the Docker container. Any reason for this?
This still happens with CUDA 12.0 :(
Docker output + nvidia-smi
== CUDA ==
CUDA Version 12.0.0
Container image Copyright (c) 2016-2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
** DEPRECATION NOTICE! **
THIS IMAGE IS DEPRECATED and is scheduled for DELETION.
    https://gitlab.com/nvidia/container-images/cuda/blob/master/doc/support-policy.md
Thu Jun 15 14:32:59 2023
|                               |                      |               MIG M. |
| 19%   47C    P8    19W / 250W |   1019MiB / 11264MiB |     14%      Default |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x55a947607c00] st: 0 edit list: 1 Missing key frame while searching for timestamp: 1000
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x55a947607c00] st: 0 edit list 1 Cannot find an index entry before timestamp: 1000.
[INFO ][14:33:01] Media format: QuickTime / MOV (mov,mp4,m4a,3gp,3g2,mj2)
terminate called after throwing an instance of 'NVDECException'
  what():  NvDecoder : cuvidCreateVideoParser(&_parser, &videoParserParameters) returned error -1953180208 at /app/modules/videocodec/nvcodec/nvdecoder.cpp:646
Ok, then I am a bit at a loss.
Is this now the exact same error as before (same code line etc.)?
My suggestion would be to try and catch the Exception and find a more verbose Error output. Maybe it would be enough to run your app in Debug because NVDECException is supposed to give you the complete Error String as a result.
What docker container image are you actually using? You are not loading directly from NGC (nvcr.io), or are you?
Thank you @MarkusHoHo .
I was able to solve it. The libcuvid libs had to be properly registered.
In my case I copy the cuvid libs from the build docker and had to copy them to the proper location and run ldconfig.
COPY --from=build /opt/nvidia/Video_Codec_SDK_12.0.16/Lib/linux/stubs/x86_64/*.so* /usr/local/cuda/lib64/stubs/
RUN echo "/usr/local/cuda/lib64/stubs\n" > /etc/ld.so.conf.d/900_video-extractor.conf && ldconfig
Thank you for sharing the solution! Much appreicated!
