Hi, i have a nvidia grid k2 gpu, and i was recently about to install nvidia-container-toolkit on my ubuntu16.04. the process of installing was successful, but when i run the command ‘docker run --gpus all --rm debian:10-slim nvidia-smi’, a errro has occurred ‘docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: detection error: nvml error: function not found: unknown.’. the information is follow:
info
Unable to find image ‘debian:10-slim’ locally
10-slim: Pulling from library/debian
f7ec5a41d630: Pull complete
Digest: sha256:b586cf8c850cada85a47599f08eb34ede4a7c473551fd7c68cbf20ce5f8dbbf1
Status: Downloaded newer image for debian:10-slim
docker: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting containvidia-container-cli: detection error: nvml error: function not found: unknown.
nvidia-smi
Wed Apr 21 11:26:56 2021
| NVIDIA-SMI 367.134 Driver Version: 367.134 |
| 0 GRID K2 Off | 0000:1A:00.0 Off | Off |
| N/A 46C P0 44W / 117W | 0MiB / 4033MiB | 0% Default |
| 1 GRID K2 Off | 0000:1B:00.0 Off | Off |
| N/A 42C P0 42W / 117W | 0MiB / 4033MiB | 0% Default |
| 2 GRID K2 Off | 0000:B1:00.0 Off | Off |
| N/A 46C P0 45W / 117W | 0MiB / 4033MiB | 0% Default |
| 3 GRID K2 Off | 0000:B2:00.0 Off | Off |
| N/A 42C P0 39W / 117W | 0MiB / 4033MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
nvidia-container-cli -V
version: 1.3.3
build date: 2021-02-05T13:29+00:00
build revision: bd9fc3f2b642345301cb2e23de07ec5386232317
build compiler: gcc-5 5.4.0 20160609
build platform: x86_64
build flags: -D_GNU_SOURCE -D_FORTIFY_SOURCE=2 -DNDEBUG -std=gnu11 -O2 -g -fdata-sections -ffunction-sections -fstack-protector -fno-strict-aliasing -fvisibility=hidden -Wall -Wextra -Wcast-align -Wpointer-arith -Wmissing-prototypes -Wnonnull -Wwrite-strings -Wlogical-op -Wformat=2 -Wmissing-format-attribute -Winit-self -Wshadow -Wstrict-prototypes -Wunreachable-code -Wconversion -Wsign-conversion -Wno-unknown-warning-option -Wno-format-extra-args -Wno-gnu-alignof-expression -Wl,-zrelro -Wl,-znow -Wl,-zdefs -Wl,–gc-sections
uname -a
Linux xidian-S2600WFT 4.15.0-142-generic #146~16.04.1-Ubuntu SMP Tue Apr 13 09:27:15 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
nvidia-container-cli -k -d /dev/tty info
– WARNING, the following logs are for debugging purposes only –
I0421 03:29:14.518588 15027 nvc.c:372] initializing library context (version=1.3.3, build=bd9fc3f2b642345301cb2e23de07ec5386232317)
I0421 03:29:14.518653 15027 nvc.c:346] using root /
I0421 03:29:14.518667 15027 nvc.c:347] using ldcache /etc/ld.so.cache
I0421 03:29:14.518678 15027 nvc.c:348] using unprivileged user 1000:1000
I0421 03:29:14.518740 15027 nvc.c:389] attempting to load dxcore to see if we are running under Windows Subsystem for Linux (WSL)
I0421 03:29:14.518880 15027 nvc.c:391] dxcore initialization failed, continuing assuming a non-WSL environment
W0421 03:29:14.528026 15028 nvc.c:269] failed to set inheritable capabilities
W0421 03:29:14.528133 15028 nvc.c:270] skipping kernel modules load due to failure
I0421 03:29:14.528714 15029 driver.c:101] starting driver service
I0421 03:29:16.399164 15027 nvc_info.c:680] requesting driver information with ‘’
I0421 03:29:16.399574 15027 nvc.c:427] shutting down library context
I0421 03:29:16.882944 15029 driver.c:156] terminating driver service
I0421 03:29:16.883197 15027 driver.c:196] driver service terminated successfully
docker --version
Docker version 20.10.6, build 370c289
i don’t know how to slove it, can anybody help me?
