Nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1
Hi everyone,
I’m trying to run this image ultralytics/yolov5:v7.0 that use an NVIDIA image. I want to run it without sudo permission, but with my user permission.
So when I try the commande using sudo, it works :
(base) mc@Lenovo-Ubuntu:~$ sudo docker run --ipc=host -it --gpus all ultralytics/yolov5:v7.0 nvidia-smi
== PyTorch ==
NVIDIA Release 22.10 (build 46164382)
PyTorch Version 1.13.0a0+d0d6b1f
Container image Copyright (c) 2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Copyright (c) 2014-2022 Facebook Inc.
Copyright (c) 2011-2014 Idiap Research Institute (Ronan Collobert)
Copyright (c) 2012-2014 Deepmind Technologies    (Koray Kavukcuoglu)
Copyright (c) 2011-2012 NEC Laboratories America (Koray Kavukcuoglu)
Copyright (c) 2011-2013 NYU                      (Clement Farabet)
Copyright (c) 2006-2010 NEC Laboratories America (Ronan Collobert, Leon Bottou, Iain Melvin, Jason Weston)
Copyright (c) 2006      Idiap Research Institute (Samy Bengio)
Copyright (c) 2001-2004 Idiap Research Institute (Ronan Collobert, Samy Bengio, Johnny Mariethoz)
Copyright (c) 2015      Google Inc.
Copyright (c) 2015      Yangqing Jia
Copyright (c) 2013-2016 The Caffe contributors
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
Thu Dec 22 11:26:40 2022
| NVIDIA-SMI 525.60.13    Driver Version: 525.60.13    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0  On |                  N/A |
| 39%   37C    P8    12W / 172W |    500MiB /  6144MiB |      1%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
Without sudo permission
BUT when I run it without the sudo permission, I get the following error:
(base) mc@Lenovo-Ubuntu:~$ docker run --ipc=host -it --gpus all ultralytics/yolov5:v7.0 nvidia-smi
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as 'legacy'
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
ERRO[0000] error waiting for container: context canceled ```
I found some topics related to my problem, but I tested the topics solutions but without success in my case..
Here is anyone ever seen this problem?
This is probably due to the fact that sudo privileges were used during the installation.
I was installing nvidia drivers and nvidia container toolkit with sudo and when I tried to run the docker container without sudo, I got the exact same error.
