Docker container error libnvidia.so.1
when i create container i get this issue.
Workstation:~$ docker run -it --gpus all -v /home/lignex1/Desktop:/workspace/sch --name 1211cudatest nvcr.io/nvidia/cuda:12.1.1-cudnn8-devel-ubuntu20.04 /bin/bash
docker: Error response from daemon: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running hook #0: error running hook: exit status 1, stdout: , stderr: Auto-detected mode as ‘legacy’
nvidia-container-cli: initialization error: load library failed: libnvidia-ml.so.1: cannot open shared object file: no such file or directory: unknown.
ERRO[0000] error waiting for container: context canceled
Does anyone know solution?
Hi
I’ve same error. Did found a solution ? I think sudo privilege is needed, but i need to compose a container i can’t use sudo commande.
