getting error while getting started with
echo “sudo docker run --runtime nvidia -it --rm --network host
–volume ~/nvdli-data:/nvdli-nano/data
–volume /tmp/argus_socket:/tmp/argus_socket
nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.4.4” > docker_dli_run.sh
chmod +x docker_dli_run.sh
./docker_dli_run.sh
error message is :
Digest: sha256:890f4d24d7bff38b509712b14a5d3e3a7923cd82a0ab4f4eab2b0cfb9d3bf8bc Status: Downloaded newer image for nvcr.io/nvidia/dli/dli-nano-ai:v2.0.1-r32.4.4 docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused "process_linux.go:432: running prestart hook 0 caused \"error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=23752 /var/lib/docker/overlay2/b312fd59fabc06627a264c91c35c8a39b6de64930b9506a9cf12e2c58ca93e76/merged]\\nnvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/b312fd59fabc06627a264c91c35c8a39b6de64930b9506a9cf12e2c58ca93e76/merged/usr/lib/aarch64-linux-gnu/libnvidia-fatbinaryloader.so.440.18: file exists\\n\""”: unknown. ERRO[2746] error waiting for container: context canceled
note: since i am using MIPI CSI camera, i had removed the --device /dev/video0 option from your command line when you run the container.
Any help in this regard?
