I’m trying to use the NVIDIA VPI library to wrap some CUDA memory with the vpiImageCreateCudaMemWrapper function. However, when the wrapped image has a stride that is not multiple of 256 it gives the following warning/error (where 512 is replaced with the next multiple of the 256 for the current width, in my case I’m using 320):
sValidateSurfacePitch: Pitch must be greater than or equal to 512 and must be a multiple of 256
NvMediaEglValidateLocalTVMROutputSurface: Pitch validation failed
NvMediaEglFillLocalImageSurface: NvMediaEglValidateLocalTVMROutputSurface failed
NvMediaEglStreamConsumerAcquireCommon: Acquire: EGLExports.stream2.consumer.publicStateGet failed (4)
[WARN ] 2020-11-20 09:41:21 src/private/mem/img/Mapping_CUDAPitch_NvMediaImage.cpp:149 (cudaEGLStreamProducerReturnFrame:cudaErrorUnknown)
[NvMediaEglStreamConsumerAcquireImage:967] Consumer acquire failed: 7
Besides this warning, the program still works fine, and the image processing looks good.
My question is if this is still a valid error, a performance issue, or if it could lead to some undefined behavior I’m not aware of, since the function documentation does not say anything about it.
