VPI image pointing to managed memory
I have a memory buffer allocated with cudaMallocManaged; this buffer is used as input to the AI model as a binding. I do the image preprocessing with the OpenCV as follows: I create and OpenCV matrix pointing to that buffer on GPU and preprocess images inplace. Like:
cv::Size inputSize = _modelConfig.inputSize;
int numBindings = engine->getNbIOTensors();
void *buffer_in, *buffer_out; // buffers for input and output of the model
int size_in = inputSize.height * inputSize.width * 3 * sizeof(float);
cudaMallocManaged(&buffer_in, size_in);
int size_out = 1 * sizeof(float); // output is juts a float number
cudaMallocManaged(&buffer_out, size_out);
void** bindings = new void*[numBindings];
bindings[0] = buffer_in;
bindings[1] = buffer_out;
// create cv::cuda::GpuMat outputMat pointing to bindings[0] what is buffer_in
cv::cuda::GpuMat outputMat = cv::cuda::GpuMat(inputSize.height, inputSize.width, CV_32FC3, bindings[0]);
preprocess outputMat with the OpenCV…
Now I want to do the same with the VPI library. But it cannot point to the Managed buffer bindings[0]. It requires whether NvBufSurface or cudaArray. Is it possible to make for example, NvBufSurface from the managed memory? What would you advice in order to make a VPIImage pointing to the bounding[0]?
With the best wishes,
Valeriy
VPI can wrap the GPU buffer.
Which VPI version do you use? 1.2 or 2.x?
I use vpi 2.
How can I wrap the GPU buffer? As I see it, the code should look like:
cudaMallocManaged(&GPU_buffer, buffer_size);
VPIIMage img_vpi;
VPIImageData img_data;
img_data.bufferType = ?;
img_data.buffer.? = GPU_buffer;
VPIStatus err_vpi = vpiImageCreateWrapper(&img_data, nullptr, VPI_BACKEND_CUDA, &img_vpi);
what should I use instead of “?”
for buffertype there are options: VPI_IMAGE_BUFFER_CUDA_PITCH_LINEAR, VPI_IMAGE_BUFFER_CUDA_ARRAY, VPI_IMAGE_BUFFER_EGLIMAGE, VPI_IMAGE_BUFFER_NVBUFFER
Could you please help me with my question?
Sorry for the late update.
Here is an example to wrap CUDA buffer with VPI 2.x for your reference:
// Given width, height, d_ptr(GPU buffer pointer)
VPIImage img;
VPIImageData data = {};
data.bufferType = VPI_IMAGE_BUFFER_CUDA_PITCH_LINEAR;
data.buffer.pitch.numPlanes = 1;
data.buffer.pitch.planes[0].width  = width;
data.buffer.pitch.planes[0].height = height;
data.buffer.pitch.planes[0].data   = d_ptr;
CHECK_STATUS(vpiImageCreateWrapper(&data, nullptr, 0, &img));
Thank you very much. I tried your code on Nvidia DevKit with Jetson AGX Xavier as follows:
void* buff;
int width = 100;
int height = 100;
cudaMalloc(&buff, width * height * 4 * sizeof(float));
VPIImage img_vpi;
VPIImageData img_data = {};
img_data.bufferType = VPI_IMAGE_BUFFER_CUDA_PITCH_LINEAR;
img_data.buffer.pitch.numPlanes = 1;
img_data.buffer.pitch.planes[0].width = width;
img_data.buffer.pitch.planes[0].height = height;
img_data.buffer.pitch.planes[0].data = buff;
VPIStatus err_vpi = vpiImageCreateWrapper(&img_data, nullptr, 0, &img_vpi);
std::cout << vpiStatusGetName(err_vpi) << std::endl;
the output is:
VPI_ERROR_INVALID_ARGUMENT
We want to check the invalid argument error in our environment.
Could you wrap the code into a runnable source and share it with us?
include
include <opencv2/cudaimgproc.hpp>
include <opencv2/imgcodecs.hpp>
include <opencv2/cudawarping.hpp> // for cv::cuda::resize
include <cuda.h>
include <cuda_runtime.h>
include <vpi/Image.h>
include <vpi/Status.h>
include <vpi/ImageFormat.h>
int main()
cuInit(0);
int img_width_output = 224;
int img_height_output = 224;
int size_output = img_width_output * img_height_output * 3 * sizeof(float);
void* output_buff; // a preprocessed image will be put here; this buffer will be used as a model input (binding)
cudaMalloc(&output_buff, size_output);
// how I do it with OpenCV GPU version
cv::Mat img_input;
cv::cuda::GpuMat img_gpu_in, img_gpu_processed;
std::string path = "304194-17086108.jpg"; // here use your image
img_input = cv::imread(path);
img_gpu_in = cv::cuda::GpuMat(img_input); // build OpenCV GPU image based on the CPU version
// wrap an OpenCV GPU image around previously allocated output_buff
img_gpu_processed = cv::cuda::GpuMat(img_height_output, img_width_output, CV_32FC3, output_buff);
cv::cuda::resize(img_gpu_in, img_gpu_processed, cv::Size(img_height_output, img_width_output), 0, 0, cv::INTER_NEAREST);
// the resulting resized image is stored in output_buff and I can use it as model input in future
// now I try to do the same with VPIimage instead of OpenCV GPU version
VPIImage img_vpi;
img_data.buffer.pitch.planes[0].width = img_width_output;
img_data.buffer.pitch.planes[0].height = img_height_output;
img_data.buffer.pitch.planes[0].pixelType = VPI_PIXEL_TYPE_3F32;
img_data.buffer.pitch.planes[0].data = output_buff;
//VPIStatus err_vpi = vpiImageCreateWrapper(&img_data, nullptr, VPI_BACKEND_CUDA, &img_vpi);
std::cout << vpiStatusGetName(err_vpi) << std::endl; // Output: VPI_ERROR_INVALID_ARGUMENT
img_gpu_in.release();
img_gpu_processed.release();
cudaFree(output_buff);
return 0;
Compile it with:
nvcc -std=c++17 -I /usr/local/cuda/include/ -I /usr/local/include/opencv4/ -I /opt/nvidia/vpi2/include/ -lcuda -lcudart -lopencv_core -lopencv_imgcodecs -lopencv_cudawarping -lnvvpi ForGuysFromNvidia.cu -o ForGuysFromNvidia
Will get back to you after checking.
Below line is not correct:
Only below is supported in VPI Image:
https://docs.nvidia.com/vpi/ImageFormat_8h.html
For example, please try this instead:
img_data.buffer.pitch.format = VPI_IMAGE_FORMAT_F32;
I replaced the line ```
with ```
but still have the same output VPI_ERROR_INVALID_ARGUMENT
Could you try if the below setting can work?
VPIImageData data;
data.buffer.pitch.format = VPI_IMAGE_FORMAT_Y8_ER;
data.buffer.pitch.planes[0].data      = image_ptr;
data.buffer.pitch.planes[0].width     = image_width;
data.buffer.pitch.planes[0].height    = image_height;
data.buffer.pitch.planes[0].pixelType = VPI_PIXEL_TYPE_DEFAULT;
I tried. The whole code is the following:
include
include <cuda.h>
int main()
cuInit(0);
cv::Mat img_input;
std::string path = "frame0001.png"; // here use your image
VPIImage img_vpi;
VPIImageData data;
//VPIStatus err_vpi = vpiImageCreateWrapper(&data, nullptr, VPI_BACKEND_CUDA, &img_vpi);
VPIStatus err_vpi = vpiImageCreateWrapper(&data, nullptr, 0, &img_vpi);
return 0;
The error is still the same.
Sorry for the late.
Please see the sample below:
#include <iostream>
#include <fstream>
#include <sstream>
#define CHECK_STATUS(STMT)                                    \
    do                                                        \
        VPIStatus status = (STMT);                            \
        if (status != VPI_SUCCESS)                            \
            char buffer[VPI_MAX_STATUS_MESSAGE_LENGTH];       \
            vpiGetLastStatusMessage(buffer, sizeof(buffer));  \
            std::ostringstream ss;                            \
            ss << "line " << __LINE__ <<": ";                 \
            ss << vpiStatusGetName(status) << ": " << buffer; \
            throw std::runtime_error(ss.str());               \
    } while (0);
int main(int argc, char *argv[])
    int width  = 224;
    int height = 224;
    int pitch  = (int((width-1)/256)+1)*256;
    char* ptr;
    cudaMalloc((void**)&ptr, pitch*height*sizeof(char));
    VPIImage img = NULL;
    data.buffer.pitch.planes[0].pitchBytes = pitch;
    data.buffer.pitch.planes[0].data       = ptr;
    vpiImageDestroy(img);
    cudaFree(ptr);
    return 0;
Thank you very much! The problem was that I didn’t use the pitch value. Could you please explain what is the idea behind this formula?
I understand that it is something with the memory layout. But what is the exact meaning and from where the 256 value comes from?
