How to convert VPIImage to cv::cuda::GpuMat ?
There is already an example to convert cv::cuda::GpuMat to VPIImage here :
I would like to see how to convert/wrap the other way around.
I think the only way is to create the image outside of VPI, e.g. cudaMalloc, and wrap it with vpiImageCreateCUDAMemWrapper or similar.
Sorry, I dont understand your answer,
I already have an VPIImage (in my case wraped from a NVBuffer).
First I want to do some processing with my VPIImage (color conversion etc.) with PVA.
After that I want to use some cv:cuda algorithmes, so I need VPIImage to cv::cuda::GpuMat.
There is currently no way to “convert” from a VPI image to any other type I guess, you can wrap existing memory however that is modified by VPI algorithms.
Say you want to convert the image you got from a NvBuffer using VPI and then process the converted image in CUDA you could do:
Then you can continue to use your converted image inside OpenCV
Ok, I understand. Thank you for the quick response and the suggested solution.
