Description of the Issue
I am attempting to deploy the NVIDIA Video Search and Summarization Agent (VSS) using Microk8s, following the official quickstart guide without any additional configuration or override values.
Previously, on February 12, 2025, I successfully installed NVIDIA VSS using Helm chart version 2.1.0. However, when attempting the same installation on March 04, 2025, I encountered errors with both Helm chart versions 2.1.0 and 2.2.0. The errors are consistent across both versions.
Steps to Reproduce
Follow the official NVIDIA VSS quickstart guide.
Use Helm chart versions 2.1.0 or 2.2.0 without additional configuration.
Yes, I have. During the initial installation, the server was clean (fresh), and I installed version 2.1.0. Later, after checking the documentation, I noticed an upgrade to version 2.2.0. I uninstalled the Helm chart, removed the PVCs, and installed the new version, but the issue persisted. To confirm, I also checked the host path, and it was already cleared.
Just from your log attached, ValueError: Unrecognized model in /tmp/tmp.vila.J4Wd8KGk.. It might be that the model is not properly downloaded, so you can try it.
