Unable to configure gpt-4o with VSS instead of vila using Openai-azure API key
I have launchpad access with 8 NVIDIA H100 NVL GPUs. I am able to deploy and use VSS with nvila but unable to use gpt-4o model with VSS replacing nvila. I followed the instructions mentioned in Nvidia documentation( Configure the VLM Video Search and Summarization Agent). Added the code from overrides file which I have modified for using gpt-4o through openai azure api key.
Below are the commands:
OPENAI_API_KEY=‘XXXXXXXXXXXXXXX’
NGC_API_KEY=‘nvapi-XXXXXXXXXXXXXXXXXXX’
kubectl create secret docker-registry ngc-docker-reg-secret --docker-server=nvcr.io --docker-username=‘$oauthtoken’ --docker-password=$NGC_API_KEY
kubectl create secret generic graph-db-creds-secret --from-literal=username=neo4j --from-literal=password=password
kubectl create secret generic openai-api-key-secret --from-literal=OPENAI_API_KEY=$OPENAI_API_KEY
helm fetch https://helm.ngc.nvidia.com/nvidia/blueprint/charts/nvidia-blueprint-vss-2.2.0.tgz --username=‘$oauthtoken’ --password=$NGC_API_KEY
helm install vss-blueprint nvidia-blueprint-vss-2.2.0.tgz --set global.ngcImagePullSecretName=ngc-docker-reg-secret -f overrides.yaml
Getting error while deploying, attached image for reference:
Content of overrides file:
vss:
  applicationSpecs:
    vss-deployment:
      containers:
        vss:
          image:
            repository: nvcr.io/nvidia/blueprint/vss-engine
            tag: 2.2.0 # Update to override with custom VSS image
          env:
            - name: VLM_MODEL_TO_USE
              value: openai-compat
            - name: OPENAI_API_KEY
              valueFrom:
                secretKeyRef:
                  key: OPENAI_API_KEY
            - name: DISABLE_GUARDRAILS
              value: "false" # "true" to disable guardrails.
            - name: TRT_LLM_MODE
              value: ""  # int4_awq (default), int8 or fp16. (for VILA only)
            - name: VLM_BATCH_SIZE
              value: ""  # Default is determined based on GPU memory. (for VILA only)
            - name: VIA_VLM_OPENAI_MODEL_DEPLOYMENT_NAME
              value: "gpt-4o"  # Set to use a VLM exposed as a REST API with OpenAI compatible API (e.g. gpt-4o)
            - name: VIA_VLM_ENDPOINT
              value: "https://usncoai0kua.openai.azure.com"  # Default OpenAI API. Override to use a custom API
            - name: VIA_VLM_API_KEY
              value: "XXXXXXXXXXXXXXXXXXXXXXX"  # API key to set when calling VIA_VLM_ENDPOINT
            - name: OPENAI_API_VERSION
              value: "2024-05-01-preview"
            - name: AZURE_OPENAI_API_VERSION
            - name: AZURE_OPENAI_ENDPOINT
  resources:
    limits:
      nvidia.com/gpu: 2   # Set to 8 for 2 x 8H100 node deployment
  # nodeSelector:
  #   kubernetes.io/hostname: <node-1>
nim-llm:
  resources:
    limits:
      nvidia.com/gpu: 4
  # nodeSelector:
  #   kubernetes.io/hostname: <node-2>
nemo-embedding:
  resources:
    limits:
      nvidia.com/gpu: 1  # Set to 2 for 2 x 8H100 node deployment
  # nodeSelector:
nemo-rerank:
  resources:
    limits:
  # nodeSelector:
Topic closed as duplication with Unable to configure gpt-4o with VSS instead of vila using Openai-azure API key - Intelligent Video Analytics / Visual AI Agent - NVIDIA Developer Forums.
