I want use Encoding method for example I want set encoderparams to NVJPEG_ENCODING_LOSSLESS_HUFFMAN Or NVJPEG_ENCODING_EXTENDED_SEQUENTIAL_DCT_HUFFMAN but failed the function nvjpegEncoderParamsSetEncoding return error code 2 mean invalid parameter. have any one know how to solve it?
int Encode::Create(cudaStream_t& stream,nvjpegBackend_t backend,
int quality,
int optimal,
nvjpegChromaSubsampling_t subsampling,
nvjpegJpegEncoding_t encoding)
params_.stream =stream;
nvjpegPinnedAllocator_t pinned; /*= {&host_malloc,&host_free}; */
nvjpegDevAllocatorV2_t dev_allocator; /* = {&dev_malloc, &dev_free};*/
CHECK_NVJPEG(nvjpegCreate(backend,NULL,¶ms_.handle))
//CHECK_NVJPEG(nvjpegCreateExV2(backend,&dev_allocator,&pinned,0,¶ms_.handle))
// CHECK_NVJPEG(nvjpegCreateSimple(¶ms_.handle))
CHECK_NVJPEG(nvjpegEncoderStateCreate(params_.handle,¶ms_.encoder_state,stream))
CHECK_NVJPEG(nvjpegEncoderParamsCreate(params_.handle,¶ms_.encoder_params,stream))
CHECK_NVJPEG(nvjpegEncoderParamsSetSamplingFactors(params_.encoder_params,subsampling,stream))
CHECK_NVJPEG(nvjpegEncoderParamsSetOptimizedHuffman(params_.encoder_params,optimal,params_.stream))
CHECK_NVJPEG(nvjpegEncoderParamsSetEncoding(params_.encoder_params,NVJPEG_ENCODING_LOSSLESS_HUFFMAN,params_.stream))
SetQuality(quality);
return 0;
