I am getting nvlink errors where a function appears to have “different sizes” :
make -f coreComponents/CMakeFiles/geosx_core.dir/build.make coreComponents/CMakeFiles/geosx_core.dir/build
make[2]: Entering directory/dev/shm/mtml/src/GEOS/GEOS/build-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo' [ 56%] Linking CUDA device code CMakeFiles/geosx_core.dir/cmake_device_link.o cd /dev/shm/mtml/src/GEOS/GEOS/build-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/coreComponents && /data/saet/mtml/software/x86_64/cmake-3.24.1-linux-x86_64/bin/cmake -E cmake_link_script CMakeFiles/geosx_core.dir/dlink.txt --verbose=1 /usr/local/cuda-11.8/bin/nvcc -forward-unknown-to-host-compiler -ccbin=/data/saet/mtml/software/x86_64/RHEL7/hpcx-v2.14-gcc-MLNX_OFED_LINUX-5-redhat7-cuda11-gdrcopy2-nccl2.16-x86_64/ompi/bin/mpic++ -restrict -arch sm_80 --expt-extended-lambda --expt-relaxed-constexpr -Werror cross-execution-space-call,reorder,deprecated-declarations -g -lineinfo -restrict -arch sm_80 --expt-extended-lambda --expt-relaxed-constexpr -Werror cross-execution-space-call,reorder,deprecated-declarations -O3 -DNDEBUG -Xcompiler -DNDEBUG -Xcompiler -Ofast --generate-code=arch=compute_80,code=[compute_80,sm_80] -Xcompiler=-fopenmp -Xcompiler=-L/usr/local/cuda-11.8/lib64 -Xlinker=-rpath -Xlinker=/data/saet/mtml/software/x86_64/RHEL7/hpcx-v2.14-gcc-MLNX_OFED_LINUX-5-redhat7-cuda11-gdrcopy2-nccl2.16-x86_64/ompi/lib -Xlinker=--enable-new-dtags -Xcompiler=-pthread -Xcompiler=-fPIC -Wno-deprecated-gpu-targets -shared -dlink CMakeFiles/geosx_core.dir/__/cmake/blt/tests/internal/src/combine_static_library_test/dummy.cpp.o -o CMakeFiles/geosx_core.dir/cmake_device_link.o -L/usr/local/cuda-11.8/targets/x86_64-linux/lib/stubs -L/usr/local/cuda-11.8/targets/x86_64-linux/lib ../lib/libcommon.a ../lib/libcodingUtilities.a ../lib/libdataRepository.a ../lib/libschema.a ../lib/libfunctions.a ../lib/libconstitutive.a ../lib/libmesh.a ../lib/libdenseLinearAlgebra.a ../lib/liblinearAlgebra.a ../lib/libfieldSpecification.a ../lib/libfiniteElement.a ../lib/libfiniteVolume.a ../lib/libdiscretizationMethods.a ../lib/libfileIO.a ../lib/libphysicsSolvers.a ../lib/libevents.a ../lib/libmainInterface.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/pugixml/lib64/libpugixml.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/mathpresso/lib/libmathpresso.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/parmetis/lib/libparmetis.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/metis/lib/libmetis.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/scotch/lib/libptscotch.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/scotch/lib/libptscotcherr.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/scotch/lib/libscotch.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/scotch/lib/libscotcherr.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/hypre/lib/libHYPRE.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/silo/lib/libsiloh5.a ../lib/libPVTPackage.a ../lib/libhdf5_interface.a ../lib/liblvarray.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/chai/lib/libchai.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/raja/lib/libRAJA.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/chai/lib/libumpire.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/raja/lib/libcamp.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/conduit/lib/libconduit_relay.a -lrt -lz -ldl -lm /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/conduit/lib/libconduit_blueprint.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/conduit/lib/libconduit.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/fmt/lib64/libfmt.a /data/saet/mtml/software/x86_64/RHEL7/GEOSTPL/0.2.0/install-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo/adiak/lib/libadiak.a /usr/local/cuda-11.8/lib64/libcudart_static.a -lpthread -lcudadevrt -lcudart_static -lmpi nvlink error : Size doesn't match for '_ZN4geos13finiteElement18ImplicitKernelBaseINS_20CellElementSubRegionENS_12constitutive11PorousSolidINS3_16ElasticIsotropicEEENS0_38H1_Hexahedron_Lagrange1_GaussLegendre2ELi3ELi3EE14StackVariablesC1Ev$582' in '../lib/libphysicsSolvers.a:PoromechanicsEFEMKernels_CellElementSubRegion_PorousSolid-ElasticIsotropic-_H1_Hexahedron_Lagrange1_GaussLegendre2.cpp.o', first specified in '../lib/libphysicsSolvers.a:SolidMechanicsFixedStressThermoPoroElasticKernels_CellElementSubRegion_PorousSolid-ElasticIsotropic-_H1_Hexahedron_Lagrange1_GaussLegendre2.cpp.o' (target: sm_80) nvlink fatal : merge_elf failed (target: sm_80) make[2]: *** [coreComponents/CMakeFiles/geosx_core.dir/cmake_device_link.o] Error 1 make[2]: TargetcoreComponents/CMakeFiles/geosx_core.dir/build’ not remade because of errors.
make[2]: Leaving directory `/dev/shm/mtml/src/GEOS/GEOS/build-GPU-Hypre-GCC-CUDA_11.8-ompi_hpcx-OMP-relwithdebinfo’
make[1]: *** [coreComponents/CMakeFiles/geosx_core.dir/all] Error 2
Any suggestions?
Michael
