I have installed CUDA Toolkit 10.2 on Ubuntu 18.04. The installer has reported:
= Summary =
Driver: Installed
Toolkit: Installed in /usr/local/cuda-10.2/
Samples: Installed in /home/myname/, but missing recommended libraries
Please make sure that
- PATH includes /usr/local/cuda-10.2/bin
- LD_LIBRARY_PATH includes /usr/local/cuda-10.2/lib64, or, add /usr/local/cuda-10.2/lib64 to /etc/ld.so.conf and run ldconfig as root
To uninstall the CUDA Toolkit, run cuda-uninstaller in /usr/local/cuda-10.2/bin
To uninstall the NVIDIA Driver, run nvidia-uninstall
Please see CUDA_Installation_Guide_Linux.pdf in /usr/local/cuda-10.2/doc/pdf for detailed information on setting up CUDA.
Logfile is /var/log/cuda-installer.log
The command
uname -a
prints
Linux myname-ThinkPad-W530 5.0.0-37-generic #40~18.04.1-Ubuntu SMP Thu Nov 14 12:06:39 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
The command
nvidia-smi
results in
Wed Dec 18 22:47:31 2019
| NVIDIA-SMI 440.33.01 Driver Version: 440.33.01 CUDA Version: 10.2 |
| 0 Quadro K1000M Off | 00000000:01:00.0 Off | N/A |
| N/A 39C P8 N/A / N/A | 590MiB / 1999MiB | 0% Default |
The command
gcc --version
results in
gcc (Ubuntu 7.4.0-1ubuntu1~18.04.1) 7.4.0
I navigated in
cd ~/NVIDIA_CUDA-10.2_Samples/0_Simple/vectorAdd
and run
make
, then I navigated in
cd ~/NVIDIA_CUDA-10.2_Samples/bin/x86_64/linux/release
and run
./vectorAdd
that yields
[Vector addition of 50000 elements]
Copy input data from the host memory to the CUDA device
CUDA kernel launch with 196 blocks of 256 threads
Copy output data from the CUDA device to the host memory
Test PASSED
Done
Then I run
sudo /usr/local/cuda-10.2/bin/nvprof --kernels vectorAdd --metrics all ./vectorAdd
that leads to
==14634== NVPROF is profiling process 14634, command: ./vectorAdd
==14634== Some kernel(s) will be replayed on device 0 in order to collect all events/metrics.
Replaying kernel "vectorAdd(float const *, float const *, float*, int)" (done)
Failed to launch vectorAdd kernel (error code unknown error)!
==14634== Error: Internal profiling error 4107:999.
======== Error: CUDA profiling error.
