I have installed CUDA Toolkit 10.2. CUDA Samples work fine, but NVIDIA Visual Profiler cannot even start to profile an application. When I click the item “PROFILE AN APPLICATION” the popup window appears:
CUDA Initialization Failed
Unable to locate CUDA libraries and establish connection with CUDA driver.
Make sure that CUDA and CUDA runtime libraries are on your path. See the installation guide for more information.
The Visual Profiler will exit now.
Of course, I have all environment variables setup: CUDA_PATH, CUDA_PATH_V10_2 both system and user variables.
If I run nvcc -V, the following result appears:
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_19:32:27_Pacific_Daylight_Time_2019
Cuda compilation tools, release 10.2, V10.2.89
CUDA Device Query results in
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "GeForce GTX 1080"
CUDA Driver Version / Runtime Version 10.2 / 10.2
CUDA Capability Major/Minor version number: 6.1
Total amount of global memory: 8192 MBytes (8589934592 bytes)
(20) Multiprocessors, (128) CUDA Cores/MP: 2560 CUDA Cores
GPU Max Clock rate: 1772 MHz (1.77 GHz)
Memory Clock rate: 5005 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 2097152 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
CUDA Device Driver Mode (TCC or WDDM): WDDM (Windows Display Driver Model)
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 1 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.2, CUDA Runtime Version = 10.2, NumDevs = 1
Result = PASS
PowerShell systeminfo prints:
OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.18363 N/A Build 18363
OS Manufacturer: Microsoft Corporation
OS Configuration: Member Workstation
OS Build Type: Multiprocessor Free
Registered Owner: N/A
Registered Organization: N/A
Original Install Date: 05/12/2019, 14:56:13
System Boot Time: 06/12/2019, 09:19:03
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: Z370 HD3
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 158 Stepping 10 GenuineIntel ~4008 Mhz
BIOS Version: American Megatrends Inc. F6, 01/03/2018
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume2
System Locale: en-us;English (United States)
Input Locale: en-us;English (United States)
Time Zone: (UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna
Total Physical Memory: 16.335 MB
Available Physical Memory: 10.720 MB
Virtual Memory: Max Size: 19.279 MB
Virtual Memory: Available: 11.558 MB
Virtual Memory: In Use: 7.721 MB
Page File Location(s): C:\pagefile.sys
Hotfix(s): 7 Hotfix(s) Installed.
[01]: KB4519573
[02]: KB4513661
[03]: KB4516115
[04]: KB4517245
[05]: KB4521863
[06]: KB4524569
[07]: KB4524570
Network Card(s): 1 NIC(s) Installed.
[01]: Intel(R) Ethernet Connection (2) I219-V
Connection Name: Ethernet
DHCP Enabled: Yes
DHCP Server: 10.24.3.1
IP address(es)
[01]: 10.24.3.140
[02]: fe80::15d6:2aa6:c956:970a
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
