I am using nvprof on my 64-bit ubuntu machine with Geforce GT 730 GPU. I get the following error when I use nvprof:
==7508== NVPROF is profiling process 7508, command: /homes/pgharat/cuda-workspace/Matrix Mul/Debug/Matrix Mul ==7508==
The visual profiler fails to work giving the same error. As far as I know, you do not need sudo privilege to run nvprof. Could someone please tell me why is this happening? How can I resolve this?
None of them worked. My machine has a:
GTX 960m,
Ubuntu 18.04,
Nvidia driver 418.56,
CUDA 10.1
I am currently downgrading everything, hopefully that will work.
Thanks Nvidia for keeping your tools (especially drivers) a terrible and time wasting experience to install, use or even remove on any Linux distribution. Keep up!
This should resolve your issue.
For persistence across reboots, we’d recommend adding this to a /etc/modprobe.d config file as mentioned on https://developer.nvidia.com/ERR_NVGPUCTRPERM
Sorry for inconvenience. Can you please try below steps, assuming you are on Linux?
Create .conf file (e.g. profile.conf) in folder /etc/modprobe.d
Open file /etc/modprobe.d/profile.conf in any editor
Add below line in profile.conf
options nvidia “NVreg_RestrictProfilingToAdminUsers=0”
Close file /etc/modprobe.d/profile.conf
Restart your machine
Also note that
[1] On some systems, it may be necessary to rebuild the initrd after writing a configuration file to /etc/modprobe.d
[2] On Ubuntu systems, when installing via the distro-native packages, the kernel module gets
renamed from nvidia to nvidia-xxx, and then nvidia is aliased to nvidia-xxx
(where xxx is the major number of the driver. So a 418.67 driver would use nvidia-418)
None of the above that you suggest works. I have not been able to use “nvprof”. I have a version of linux Ubuntu 16.04.6 LTS with the driver nvidia-418. Has anyone solved the problem?
Hello, I’m trying to profile a Python application on a Jetson TX2 (using JetPack 4.3), and I am not able to run nvprof with sudo, as the Python modules my program uses are inside a virtual environment, which root has not visibility of.
When trying to run the program, I obtain the following result:
$ nvprof python tester.py
Successfully opened dynamic library libcudart.so.10.0
[Some initialization messages from my program itself...]
2020-02-03 13:52:08.536904: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
==7580== NVPROF is profiling process 7580, command: python tester.py
==7580== Warning: Insufficient privileges to start the profiling session. Use root privileges
==7580== Profiling application: python tester.py
==7580== Profiling result:
No kernels were profiled.
No API activities were profiled.
I’ve tried several of the solutions provided above, and tried on the service “nvgpu” instead of “nvidia” as it does not exist with that name. However, I ever obtain the same result (the posted above), even after rebooting before trying again. According to the https://developer.nvidia.com/nvidia-development-tools-solutions-err-nvgpuctrperm-nvprofinstructions provided in this thread, it would be useful to set the CAP_SYS_ADMIN capability on my user, and in the nvprof file. I’ve done so with:
$ capsh --print
Current: = cap_sys_admin+i
getcap /usr/local/cuda/bin/nvprof
Neither of these solutions worked. Is there any other way to try to get it working?
which suggests that the module is used by some process, but I cannot find them. Due to this, I cannot unload the old nvidia module. I tried to skip this step and followed remaining steps, but the problem is not solved.
I tried to change RmProfilingAdminOnly to 0 by adding options nvidia “NVreg_RestrictProfilingToAdminUsers=0” to /etc/modprobe.d/profile.conf and rebooted my server, but RmProfilingAdminOnly is still 1 after reboot.
I also added myself to CAP_SYS_ADMIN set, but I still cannot use the nvprof.
I’m using a DGX Station, the driver version is 418.116.00 with CUDA 10.1. Is there any other way to solve this problem?
Nvidia Visual Profiler and nvprof don’t support profiling on Tegra devices (like Jetson TX2) for non-root users. The only workaround is to start the profiling session as a root user.
For container image provided by NVIDIA, I think nvprof can be used directly without requiring any docker specific setting as CUDA toolkit is included in the image.
For the cases where user maps the CUDA toolkit into docker, we need to set PATH and LD_LIBRARY_PATH.
Starting with CUDA 10.2, user might additionally need to set the LD_LIBRARY_PATH to <toolkit_root_dir>/extras/CUPTI/lib64 as nvprof now uses shared CUPTI library. More details at the docs portal Profiler :: CUDA Toolkit Documentation.
