Cannot profile Jetson Xavier with jetpack 4.4
Hi ,
During lunch Nvprov over my Jetson I got follwing error:
[polar_mgbp.cpp@66][2020-Nov-15 14:15:36.017673] <3> : -if inputFile: /home/nvidia/work/xii/daemon/sigdat/xaver-demo-2002b-ball.dat
Have 28 channels in input file, each having 872 samples.
========= Could not find parameter devid, using DEFAULT value instead = 0.000000 =========
==10024== NVPROF is profiling process 10024, command: /home/nvidia/work/xii/daemon/src/build/polar_mgbp -cfgFile /home/nvidia/work/xii/daemon/cfg/x4.cfg -if /home/nvidia/work/xii/daemon/sigdat/xaver-demo-2002b-ball.dat -dumpImage 0 -log 3 -RECON::useGpu 1 -IF::SKIP 2
==10024== Warning: ERR_NVGPUCTRPERM - The user does not have permission to profile on the target device. See the following link for instructions to enable permissions and get more information: https://developer.nvidia.com/ERR_NVGPUCTRPERM
==10024== Generated result file: /tmp/nvvp_nvidia/launch/0/api_10024.log
logout
I tried to solve the issue by using the link https://developer.nvidia.com/ERR_NVGPUCTRPERM but it looks like a solution for desktop and not embedded systems.
The system:
Jepack 4.4
Nvidia Xavier 16Gb
How can I solve the issue in order to be able to perform profiing over this target?
Regrads
Yehonatan Spiegel.
CUDA profiling require root privilege.
If you run nvprof on the device, please use $ sudo /usr/local/cuda-10.2/bin/nvprof ...
If you run it remotely, please following below topic to ssh with root account.
