NvRmMemInitNvmap failed / NVMAP permission denied when launching nvcr.io/nvidia/vllm:25.11-py3 container on Jetson Orin NX + JetPack 6.2 (L4T 36.4.3)
NvRmMemInitNvmap failed _ NVMAP permission denied when launching nvcr.io_nvidia_vllm_25.11-py3 container on Jetson Orin NX + JetPack 6.2 (L4T 36.4.3).pdf (1.2 MB)
Hi!
When I run the nvcr.io/nvidia/vllm:25.11 container with GPU support, I get the following error message. Even when I start the container with --privileged, the same error still occurs.
(I have also compiled the text and images below into a PDF, hoping it will be helpful to you.)
sudo docker run -d -t \
--net=host \
--gpus all \
--ipc=host \
--name vllm \
-v /home/unitree/models:/workspace/models \
--restart=unless-stopped \
1f47c643e288aeecfe37efa3d9691a801e4670321c10572c3c76975b9292c8ff
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error running prestart hook #0: exit status 1, stdout: , stderr: NvRmMemInitNvmap failed with Permission denied
356: Memory Manager Not supported
NvRmMemMgrInit failed error type: 196626
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=196626
nvidia-container-cli: detection error: nvml error: unknown error
Run ‘docker run --help’ for more information
--net=host \
--gpus all \
–privileged \
--ipc=host \
--name vllm \
[sudo] password for unitree:
d1d87ba2a83a8c2e2d6e6d53ecdc8f997a5b1275284bfe968bd94fc72b037f7f
This is “id ${USER}”.
unitree@unitree-g1-nx:~/xp/jetson-containers$ id ${USER}
uid=1000(unitree) gid=1000(unitree) groups=1000(unitree),4(adm),24(cdrom),27(sudo),29(audio),30(dip),44(video),46(plugdev),104(render),116(i2c),120(lpadmin),135(gdm),999(gpio),996(weston-launch),136(sambashare),1001(jtop),994(docker)
This is “docker inspect nvcr.io/nvidia/vllm:25.11-py3”.
unitree@unitree-g1-nx:~$ docker inspect nvcr.io/nvidia/vllm:25.11-py3
“Id”: “sha256:c94cef75a33ff40dd34d45429809d840b64f416f957fbe73af11944213b6b994”,
“RepoTags”: [
“RepoDigests”: [
nvcr.io/nvidia/vllm@sha256:c94cef75a33ff40dd34d45429809d840b64f416f957fbe73af11944213b6b994
“Comment”: “buildkit.dockerfile.v0”,
“Created”: “2025-11-08T11:13:00.160179947Z”,
“Config”: {
“Env”: [
“PATH=/usr/local/lib/python3.12/dist-packages/torch_tensorrt/bin:/usr/local/cuda/bin:/usr/local/nvidia/bin:/usr/local/cuda/bin:/usr/local/mpi/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/ucx/bin:/opt/amazon/efa/bin:/opt/tensorrt/bin”,
“NVIDIA_REQUIRE_JETPACK_HOST_MOUNTS=”,
“GDRCOPY_VERSION=2.5.1”,
“HPCX_VERSION=2.24.1”,
“MOFED_VERSION=5.4-rdmacore56.0”,
“OPENUCX_VERSION=1.19.0”,
“OPENMPI_VERSION=4.1.7”,
“RDMACORE_VERSION=56.0”,
“EFA_VERSION=1.43.1”,
“AWS_OFI_NCCL_VERSION=1.17.0”,
“OPAL_PREFIX=/opt/hpcx/ompi”,
“OMPI_MCA_coll_hcoll_enable=0”,
“CUDA_VERSION=13.0.2.006”,
“CUDA_DRIVER_VERSION=580.95.05”,
“NVVM_VERSION=13.0.88”,
“DOCA_VERSION=3.1.0”,
“_CUDA_COMPAT_PATH=/usr/local/cuda/compat”,
“ENV=/etc/shinit_v2”,
“BASH_ENV=/etc/bash.bashrc”,
“SHELL=/bin/bash”,
“NVIDIA_REQUIRE_CUDA=cuda>=9.0”,
“NCCL_VERSION=2.28.8”,
“CUBLAS_VERSION=13.1.0.3”,
“CUFFT_VERSION=12.0.0.61”,
“CURAND_VERSION=10.4.0.35”,
“CUSPARSE_VERSION=12.6.3.3”,
“CUSPARSELT_VERSION=0.8.1.1”,
“CUSOLVER_VERSION=12.0.4.66”,
“NPP_VERSION=13.0.1.2”,
“NVJPEG_VERSION=13.0.1.86”,
“CUFILE_VERSION=1.15.1.6”,
“NVJITLINK_VERSION=13.0.88”,
“NVFATBIN_VERSION=13.0.85”,
“CUBLASMP_VERSION=0.6.0.84”,
“NVSHMEM_VERSION=3.4.5”,
“CUDLA_VERSION=13.0.2.006”,
“NVPTXCOMPILER_VERSION=13.0.88”,
“CUDNN_VERSION=9.15.0.58”,
“CUDNN_FRONTEND_VERSION=1.15.0”,
“TRT_VERSION=10.14.1.48”,
“TRTOSS_VERSION=”,
“NSIGHT_SYSTEMS_VERSION=2025.5.1.121”,
“NSIGHT_COMPUTE_VERSION=2025.3.1.4”,
“DALI_VERSION=1.52.0”,
“DALI_BUILD=”,
“DALI_URL_SUFFIX=130”,
“POLYGRAPHY_VERSION=0.49.26”,
“TRANSFORMER_ENGINE_VERSION=2.9”,
“MODEL_OPT_VERSION=0.37.0”,
“CUDA_ARCH_LIST=8.0 8.6 9.0 10.0 11.0 12.0”,
“MAXSMVER=121”,
“NVRX_VERSION=0.4.1+cuda13”,
“LD_LIBRARY_PATH=/usr/local/lib/python3.12/dist-packages/torch/lib:/usr/local/lib/python3.12/dist-packages/torch_tensorrt/lib:/usr/local/cuda/compat/lib:/usr/local/nvidia/lib:/usr/local/nvidia/lib64”,
“NVIDIA_VISIBLE_DEVICES=all”,
“NVIDIA_DRIVER_CAPABILITIES=compute,utility,video”,
“NVIDIA_PRODUCT_NAME=vLLM”,
“CUDA_COMPONENT_LIST=cccl crt nvrtc driver-dev culibos-dev cudart cudart-dev nvcc”,
“LIBRARY_PATH=/usr/local/cuda/lib64/stubs:”,
“VLLM_VERSION=0.11.0+582e4e37”,
“PIP_CONSTRAINT=/etc/pip/constraint.txt”,
“CUDA_HOME=/usr/local/cuda”,
“CPATH=/usr/local/cuda/include:”,
“TORCH_CUDA_ARCH_LIST=8.0 8.6 9.0 10.0 11.0 12.0+PTX”,
“TRITON_PTXAS_PATH=/usr/local/cuda/bin/ptxas”,
“TRITON_CUOBJDUMP_PATH=/usr/local/cuda/bin/cuobjdump”,
“TRITON_NVDISASM_PATH=/usr/local/cuda/bin/nvdisasm”,
“TRITON_CUDACRT_PATH=/usr/local/cuda/include”,
“TRITON_CUDART_PATH=/usr/local/cuda/include”,
“TRITON_CUPTI_PATH=/usr/local/cuda/include”,
“MAX_JOBS=12”,
“PIP_BREAK_SYSTEM_PACKAGES=1”,
“PIP_NO_BUILD_ISOLATION=1”,
“PYTORCH_TRITON_VERSION=3.5.0+git8daff01a”,
“TIKTOKEN_CACHE_DIR=/root/.cache/tiktoken_cache”,
“TIKTOKEN_RS_CACHE_DIR=/root/.cache/tiktoken_cache”,
“NVIDIA_VLLM_VERSION=25.11”,
“NVIDIA_BUILD_ID=231063344”
“Entrypoint”: [
“/opt/nvidia/nvidia_entrypoint.sh”
“WorkingDir”: “/workspace”,
“Labels”: {
“com.nvidia.build.id”: “231063344”,
“com.nvidia.build.ref”: “70a7e4b3c87282a4cb66684ed2ae82174aa991a2”,
“com.nvidia.cublas.version”: “13.1.0.3”,
“com.nvidia.cuda.version”: “9.0”,
“com.nvidia.cudnn.version”: “9.15.0.58”,
“com.nvidia.cufft.version”: “12.0.0.61”,
“com.nvidia.curand.version”: “10.4.0.35”,
“com.nvidia.cusolver.version”: “12.0.4.66”,
“com.nvidia.cusparse.version”: “12.6.3.3”,
“com.nvidia.cusparselt.version”: “0.8.1.1”,
“com.nvidia.nccl.version”: “2.28.8”,
“com.nvidia.npp.version”: “13.0.1.2”,
“com.nvidia.nvjpeg.version”: “13.0.1.86”,
“com.nvidia.vllm.version”: “0.11.0+582e4e37”,
“com.nvidia.volumes.needed”: “nvidia_driver”,
“org.opencontainers.image.ref.name”: “ubuntu”,
“org.opencontainers.image.version”: “24.04”
“Architecture”: “arm64”,
“Os”: “linux”,
“Size”: 6105891268,
“RootFS”: {
“Type”: “layers”,
“Layers”: [
“sha256:ab34259f9ca5d315bec1b17d9f1ca272e84dedd964a8988695daf0ec3e0bbc2e”,
“sha256:5f70bf18a086007016e948b04aed3b82103a36bea41755b6cddfaf10ace3c6ef”
“Metadata”: {
“LastTagTime”: “2025-12-09T06:58:27.878443023Z”
“Descriptor”: {
“mediaType”: “application/vnd.docker.distribution.manifest.list.v2+json”,
“digest”: “sha256:c94cef75a33ff40dd34d45429809d840b64f416f957fbe73af11944213b6b994”,
“size”: 743
This is “jetson_release”.
unitree@unitree-g1-nx:~/xp/temp$ sudo jetson_release
Software part of jetson-stats 4.3.2 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Jetson Orin NX Engineering Reference Developer Kit - Jetpack 6.2 [L4T 36.4.3]
NV Power Mode[2]: 15W
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
  • P-Number: p3767-0000
  • Module: NVIDIA Jetson Orin NX (16GB ram)
Platform:
  • Distribution: Ubuntu 22.04 Jammy Jellyfish
  • Release: 5.15.148-tegra
jtop:
  • Version: 4.3.2
  • Service: Active
Libraries:
  • CUDA: Not installed
  • cuDNN: Not installed
  • TensorRT: Not installed
  • VPI: Not installed
  • Vulkan: 1.3.204
  • OpenCV: 4.5.4 - with CUDA: NO
This is “cat /etc/nv_tegra_release”.
unitree@unitree-g1-nx:~/xp/temp$ cat /etc/nv_tegra_release
R36 (release), REVISION: 4.3, GCID: 38968081, BOARD: generic, EABI: aarch64, DATE: Wed Jan 8 01:49:37 UTC 2025
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
This is “nvidia-smi”.
This is “jtop”.
This is “docker --version”.
unitree@unitree-g1-nx:~/xp/temp$ docker --version
Docker version 29.1.2, build 890dcca
unitree@unitree-g1-nx:~/xp/temp$ sudo systemctl status docker
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2025-12-10 17:13:43 CST; 10min ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Main PID: 158962 (dockerd)
Tasks: 18
Memory: 43.4M
CPU: 1.630s
CGroup: /system.slice/docker.service
└─158962 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
This is “docker info”. As you can see, I’ve added mirror sources to the “registry-mirrors” section. This is because I’m in China and can’t pull images from docker.io directly. However, even with these mirrors, I still can’t use them.
unitree@unitree-g1-nx:~/xp/temp$ docker info
Client: Docker Engine - Community
Version: 29.1.2
Context: default
Debug Mode: false
Plugins:
buildx: Docker Buildx (Docker Inc.)
Version: v0.30.1
Path: /usr/libexec/docker/cli-plugins/docker-buildx
compose: Docker Compose (Docker Inc.)
Version: v5.0.0
Path: /usr/libexec/docker/cli-plugins/docker-compose
Server:
Containers: 11
Running: 1
Paused: 0
Stopped: 10
Images: 2
Server Version: 29.1.2
Storage Driver: overlayfs
driver-type: io.containerd.snapshotter.v1
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local splunk syslog
CDI spec directories:
/etc/cdi
/var/run/cdi
Swarm: inactive
Runtimes: io.containerd.runc.v2 nvidia runc
Default Runtime: nvidia
Init Binary: docker-init
containerd version: 1c4457e00facac03ce1d75f7b6777a7a851e5c41
runc version: v1.3.4-0-gd6d73eb8
init version: de40ad0
Security Options:
seccomp
Profile: builtin
cgroupns
Kernel Version: 5.15.148-tegra
Operating System: Ubuntu 22.04.5 LTS
OSType: linux
Architecture: aarch64
CPUs: 4
Total Memory: 15.29GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Experimental: false
Insecure Registries:
::1/128
127.0.0.0/8
Registry Mirrors:
https://hub-mirror.c.163.com/
https://mirror.aliyuncs.com/
https://docker.mirrors.ustc.edu.cn/
https://nvcr.io-mirror.nvidia.com/
Live Restore Enabled: false
Firewall Backend: iptables
unitree@unitree-g1-nx:~/xp/temp$ docker run --rm --gpus all nvidia/cuda:12.4.1-base-ubuntu22.04 nvidia-smi
Unable to find image ‘nvidia/cuda:12.4.1-base-ubuntu22.04’ locally
docker: Error response from daemon: failed to resolve reference “docker.io/nvidia/cuda:12.4.1-base-ubuntu22.04”: failed to do request: Head "https://hub-mirror.c.163.com/v2/nvidia/cuda/manifests/12.4.1-base-ubuntu22.04?ns=docker.io": dial tcp: lookup hub-mirror.c.163.com on 223.5.5.5:53: no such host
This is “nvidia-ctk -h
unitree@unitree-g1-nx:~/xp/temp$ nvidia-ctk -h
NAME:
NVIDIA Container Toolkit CLI - Tools to configure the NVIDIA Container Toolkit
USAGE:
nvidia-ctk [global options] command [command options] [arguments…]
VERSION:
1.13.5
commit: 6b8589dcb4dead72ab64f14a5912886e6165c079
COMMANDS:
hook A collection of hooks that may be injected into an OCI spec
runtime A collection of runtime-related utilities for the NVIDIA Container Toolkit
info Provide information about the system
cdi Provide tools for interacting with Container Device Interface specifications
system A collection of system-related utilities for the NVIDIA Container Toolkit
help, h Shows a list of commands or help for one command
GLOBAL OPTIONS:
--debug, -d Enable debug-level logging (default: false) [$NVIDIA_CTK_DEBUG]
--help, -h show help (default: false)
--version, -v print the version (default: false)
This is “nvidia-container-runtime --version
unitree@unitree-g1-nx:~/xp/temp$ nvidia-container-runtime --version
NVIDIA Container Runtime version 1.13.5
spec: 1.1.0-rc.2
runc version 1.3.4
commit: v1.3.4-0-gd6d73eb8
spec: 1.2.1
go: go1.24.9
libseccomp: 2.5.3
This is “jetson-containers run $(autotag vllm)”. I also tried installing vllm with jetson-containers, but it didn’t work either.
unitree@unitree-g1-nx:~$ jetson-containers run $(autotag vllm)
Namespace(packages=[‘vllm’], prefer=[‘local’, ‘registry’, ‘build’], disable=[‘’], user=‘dustynv’, output=‘/tmp/autotag’, quiet=False, verbose=False)
-- L4T_VERSION=36.4.3 JETPACK_VERSION=6.2 CUDA_VERSION=12.6
-- Finding compatible container image for [‘vllm’]
V4L2_DEVICES:
  • docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/unitree/xp/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-7 --device /dev/i2c-9 -v /run/jtop.sock:/run/jtop.sock --name jetson_container_20251210_174314 nvcr.io/nvidia/vllm:25.11-py3
This is “jetson-containers commit hash”.
unitree@unitree-g1-nx:~/xp/jetson-containers$ git rev-parse HEAD
62bc36d9efb3056b67403ed096c5df8edf7f6f8f
Project source and local modification about jetson-containers:
I cloned the jetson-containers repository through the China mirror
git clone https://gitclone.com/github.com/dusty-nv/jetson-containers.git
and the only file I changed is jetson-containers/requirements.txt.
The original line
git+https://github.com/Granulate/DockerHub-API.git
was unreachable from China, so I replaced it with
git+https://gitclone.com/github.com/Granulate/DockerHub-API.git
(all other lines remain identical).
After that I simply ran bash install.sh to set up the tool.
The container requires the SBSA GPU driver but Orin uses nvgpu instead.
Please try the container below that was built for the Orin series:
Hi~
I executed the following command on my local Linux x86 machine:
docker pull --platform linux/arm64 dustynv/vllm:r36.4-cu129-24.04
Then I ran:
docker inspect dustynv/vllm:r36.4-cu129-24.04
Here is the output:
root@unitree-g1-nx:/home/unitree# docker inspect dustynv/vllm:r36.4-cu129-24.04
"Id": "sha256:14b99e86bd00e940626d61919c93723bbd77a87ff3e61640a11ca55210b0dd88",
"RepoTags": [
"dustynv/vllm:r36.4-cu129-24.04"
"RepoDigests": [
"dustynv/vllm@sha256:14b99e86bd00e940626d61919c93723bbd77a87ff3e61640a11ca55210b0dd88"
"Created": "2025-07-07T02:48:58.933436399Z",
"Config": {
"Env": [
"PATH=/root/.cargo/bin:/opt/venv/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"DEBIAN_FRONTEND=noninteractive",
"LANGUAGE=en_US:en",
"LANG=en_US.UTF-8",
"LC_ALL=en_US.UTF-8",
"WGET_FLAGS=--quiet --show-progress --progress=bar:force:noscroll --no-check-certificate",
"MULTIARCH_URL=https://apt.jetson-ai-lab.dev/multiarch",
"TAR_INDEX_URL=https://apt.jetson-ai-lab.dev/jp6/cu129/24.04",
"PIP_INDEX_URL=https://pypi.jetson-ai-lab.dev/jp6/cu129",
"PIP_TRUSTED_HOST=",
"TWINE_REPOSITORY_URL=http://localhost/jp6/cu129",
"TWINE_USERNAME=jp6",
"TWINE_PASSWORD=none",
"SCP_UPLOAD_URL=localhost:/dist/jp6/cu129/24.04",
"SCP_UPLOAD_USER=None",
"SCP_UPLOAD_PASS=None",
"CUDA_HOME=/usr/local/cuda",
"NVCC_PATH=/usr/local/cuda/bin/nvcc",
"NVIDIA_VISIBLE_DEVICES=all",
"NVIDIA_DRIVER_CAPABILITIES=all",
"CUDAARCHS=87",
"CUDA_ARCHITECTURES=87",
"CUDNN_LIB_PATH=/usr/lib/aarch64-linux-gnu",
"CUDNN_LIB_INCLUDE_PATH=/usr/include",
"CMAKE_CUDA_COMPILER=/usr/local/cuda/bin/nvcc",
"CUDA_NVCC_EXECUTABLE=/usr/local/cuda/bin/nvcc",
"CUDACXX=/usr/local/cuda/bin/nvcc",
"TORCH_NVCC_FLAGS=-Xfatbin -compress-all",
"CUDA_BIN_PATH=/usr/local/cuda/bin",
"CUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda",
"LD_LIBRARY_PATH=/usr/local/cuda/compat:/usr/local/cuda/lib64:",
"PYTHON_VERSION=3.12",
"PYTHONFAULTHANDLER=1",
"PYTHONUNBUFFERED=1",
"PYTHONIOENCODING=utf-8",
"PYTHONHASHSEED=random",
"PIP_NO_CACHE_DIR=true",
"PIP_CACHE_PURGE=true",
"PIP_ROOT_USER_ACTION=ignore",
"PIP_DISABLE_PIP_VERSION_CHECK=on",
"PIP_DEFAULT_TIMEOUT=100",
"PIP_WHEEL_DIR=/opt/wheels",
"PIP_VERBOSE=1",
"TWINE_NON_INTERACTIVE=1",
"OPENBLAS_CORETYPE=ARMV8",
"DYNAMIC_ARCH=1",
"NUMPY_PACKAGE=numpy",
"NUMPY_VERSION_MAJOR=2",
"TORCH_CUDA_ARCH_LIST=8.7",
"PIP_EXTRA_INDEX_URL=",
"TORCH_HOME=/data/models/torch",
"TRANSFORMERS_CACHE=/data/models/huggingface",
"HUGGINGFACE_HUB_CACHE=/data/models/huggingface",
"HF_HOME=/data/models/huggingface",
"TRANSFORMERS_PACKAGE=",
"TRANSFORMERS_VERSION=",
"DIFFUSERS_FORCE_DISABLE_TRITON=1",
"XFORMERS_FORCE_DISABLE_TRITON=1"
"Cmd": [
"/bin/bash"
"WorkingDir": "/",
"Labels": {
"org.opencontainers.image.ref.name": "ubuntu",
"org.opencontainers.image.version": "24.04"
"Architecture": "arm64",
"Variant": "v8",
"Os": "linux",
"Size": 17649327685,
"RootFS": {
"Type": "layers",
"Layers": [
"sha256:ccd2cfe57c25db3597f049070e10ffe286c34a12ccaadcf69ce28543ce350979",
.....many sha256 layers.....             "sha256:222616c338ab81efc5688bc4b53e83d65099a9d0098b86326220dedec64d3235"
"Metadata": {
"LastTagTime": "2025-12-17T03:21:00.257241877Z"
"Descriptor": {
"mediaType": "application/vnd.docker.distribution.manifest.v2+json",
"digest": "sha256:14b99e86bd00e940626d61919c93723bbd77a87ff3e61640a11ca55210b0dd88",
"size": 12309,
"annotations": {
"io.containerd.image.name": "docker.io/dustynv/vllm:r36.4-cu129-24.04",
"org.opencontainers.image.ref.name": "r36.4-cu129-24.04"
After that, I performed the following operations on the image dustynv/vllm:r36.4-cu129-24.04 :
  • Export the image :
docker save -o /mnt/sda-20T/xupeng/docker_images/vllm-jetson.tar dustynv/vllm:r36.4-cu129-24.04
  • Transfer the image to Jetson orin nx :
rsync -avz /mnt/sda-20T/xupeng/docker_images/vllm-jetson.tar unitree@172.16.22.27:/home/unitree/xp/docker_images/
  • Change permissions :
sudo chmod -R 777 /home/unitree/xp/docker_images/
  • Load the image :
docker load -i /home/unitree/xp/docker_images/vllm-jetson.tar
  • Run the container :
docker run --rm -it --shm-size 2g --ipc host --gpus all --ulimit memlock=-1 --ulimit stack=67108864 -v  /home/unitree/models:/workspace/models -p 8000:8000 dustynv/vllm:r36.4-cu129-24.04
However, when I executed the docker run command, I encountered an error. The error message is as follows:
unitree@unitree-g1-nx:~$ docker run --rm -it --shm-size 2g --ipc host --gpus all --ulimit memlock=-1 --ulimit stack=67108864 -v  /home/unitree/models:/workspace/m
WARNING: IPv4 forwarding is disabled. Networking will not work.
Run 'docker run --help' for more information
What could be the issue? I look forward to your reply. Thank you!
Hi~
I would be very grateful if you could help me with my question. I really need your help, thanks.
~0121
Could you try to launch to container with sudo to see if it can work?
