I have a custom deepstream camera element that outputs 3 images in a batched buffer.
I create my output buffer and metadata like this.
NvBufSurface *frames_surf[framesCount];
for (int i = 0; i < framesCount; i++)
NvArgusFrameInfo *consumerFrameInfo = consumerFrameInfos->at(i);
if (&consumerFrameInfo->fd == NULL)
goto done;
retn = NvBufSurfaceFromFd(consumerFrameInfo->fd, (void **)(&frames_surf[i]));
if (retn != 0)
GST_ERROR_OBJECT(src, "NvBufSurfaceFromFd Failed");
goto done;
GstMapInfo outmap = GST_MAP_INFO_INIT;
gst_buffer_map(buffer, &outmap, GST_MAP_WRITE);
NvBufSurface *out_surf = (NvBufSurface *)outmap.data;
GST_INFO_OBJECT(src, "NvBufSurface + batch size %d\n", out_surf->batchSize);
GST_HAKOB_PRINT("NvBufSurface + batch size %d\n", out_surf->batchSize);
g_assert(out_surf->batchSize == src->sensors_num);
g_assert(out_surf->batchSize >= consumerFrameInfos->size());
NvBufSurface in_surf = {0};
NvBufSurfaceParams surfaceList[out_surf->batchSize];
in_surf.surfaceList = &surfaceList[0];
in_surf.batchSize = out_surf->batchSize;
in_surf.numFilled = framesCount;
in_surf.surfaceList[i] = frames_surf[i]->surfaceList[0];
retn = NvBufSurfTransform(&in_surf, out_surf, &src->transform_params);
if (retn != 0)
GST_ERROR_OBJECT(src, "NvBufSurfTransform Failed");
/* TODO: Check if need to set ->stop_requested flag in error condition */
goto done;
NvDsBatchMeta *batch_meta = nvds_create_batch_meta(src->sensors_num);
g_assert(batch_meta);
NvDsMeta *nvds_meta = gst_buffer_add_nvds_meta(buffer, batch_meta, NULL,
nvds_batch_meta_copy_func, nvds_batch_meta_release_func);
g_assert(nvds_meta);
nvds_meta->meta_type = NVDS_BATCH_GST_META;
batch_meta->base_meta.batch_meta = batch_meta;
batch_meta->base_meta.copy_func = nvds_batch_meta_copy_func;
batch_meta->base_meta.release_func = nvds_batch_meta_release_func;
batch_meta->max_frames_in_batch = src->sensors_num;
// batch_meta->num_frames_in_batch = framesCount;
GST_DEBUG_OBJECT(src, "consumer fill frame meta %d", i);
NvArgusFrameInfo *frameInfo = consumerFrameInfos->at(i);
// attach frame meta
NvDsFrameMeta *frame_meta = nvds_acquire_frame_meta_from_pool(batch_meta);
g_assert(frame_meta);
g_assert(frame_meta->base_meta.batch_meta == batch_meta);
frame_meta->pad_index = i;
frame_meta->batch_id = i;
frame_meta->frame_num = frameInfo->frameNum;
frame_meta->buf_pts = frameInfo->frameTime;
frame_meta->ntp_timestamp = get_ntp_timestamp();
frame_meta->source_id = src->sensors[i];
frame_meta->num_surfaces_per_frame = 1;
// TODO : remove hardcoding
frame_meta->source_frame_width = 4032;
frame_meta->source_frame_height = 3040;
nvds_add_frame_meta_to_batch(batch_meta, frame_meta);
if (batch_meta->num_frames_in_batch != framesCount)
GST_ERROR_OBJECT(src, "consumer fill output batch meta failed");
break;
This element is attached to nvstreamdemux, but for some reason the output from nvstreamdemux is empty.
I got this error message from the logs I am getting this from my nvstreamdemux element
GST_CAPS gstpad.c:2704:gst_pad_has_current_caps:demux:src_0 check current pad caps (NULL)
GST_CAPS gstpad.c:2704:gst_pad_has_current_caps:demux:src_1 check current pad caps (NULL)
GST_CAPS gstpad.c:2704:gst_pad_has_current_caps:demux:src_2 check current pad caps (NULL)
Here is my full pipeline, where nvarguscamerahakob is my custom element/
gst-launch-1.0 -e nvarguscamerahakob silent=true ! "video/x-raw(memory:NVMM),format=(string)RGBA,width=(int)4032,height=(int)3040,framerate=(fraction)29/1" ! queue ! \
nvstreamdemux name=demux \
demux.src_0 ! nvv4l2h264enc bitrate=60000000 insert-sps-pps=true ! h264parse ! qtmux ! filesink location=video1.mp4 \
demux.src_1 ! nvv4l2h264enc bitrate=60000000 insert-sps-pps=true ! h264parse ! qtmux ! filesink location=video2.mp4 \
demux.src_2 ! nvv4l2h264enc bitrate=60000000 insert-sps-pps=true ! h264parse ! qtmux ! filesink location=video3.mp4
For testing purposes, I created another custom element and was able to fully read the output, which proves the images are going to the downstream component.
Can you please help me to understand how to debug this and find out what is going wrong?
