Nvv4l2decoder failure
• Hardware Platform (Jetson / GPU) ORIN
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version 10.3.0.30
When using capture-main.py for RTSP stream retrieval:
  • Successful stream capture occurs when using avdec_h264 decoder
  • Failure occurs when using nvv4l2decoder
capture-main.py is shown below
import cv2
import time
def capture():
    # 启动拉流
    url = "rtsp://192.168.137.1:554/1"
    gst_str = (
        'rtspsrc location={} latency=200 protocols=4 '
        '! rtph264depay '
        '! h264parse '
        '! nvv4l2decoder enable-max-performance=1 '
        '! nvvidconv output-buffers=2 '
        '! video/x-raw, format=BGRx '
        '! videoconvert '
        '! video/x-raw, format=BGR '
        '! appsink drop=true sync=false max-buffers=10'
    ).format(url)
    #gst_str = (
    #    'rtspsrc location={} latency=200 protocols=4 '
    #    '! rtph264depay '
    #    '! h264parse '
    #    '! avdec_h264 '
    #    '! nvvidconv output-buffers=2 '
    #    '! video/x-raw, format=BGRx '
    #    '! videoconvert '
    #    '! video/x-raw, format=BGR '
    #    '! appsink drop=true sync=false max-buffers=10'
    #).format(url)
    cap = None
    frame_num = 0
    while True:
        print("before VideoCapture")
        #cap = cv2.VideoCapture(url) #OK
        cap = cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
        print("after VideoCapture")
        flag = True if cap.isOpened() else False
        # ret, img = cap.read()
        if flag:
            print('VideoCapture success')
        else:
            print('VideoCapture failed')
            cap.release()
            time.sleep(0.1)
            continue
        while(flag):
            flag, img = cap.read()
            # logger.debug("Pantographs structure analysis, time %f" % (time.time() - time_start1))
            # 执行分析
            if img is None:
                print('>>> Image data is None , drop it !')
                time.sleep(0.001)
                continue
            print("cap.read")
            frame_num += 1
            #analysis(frame_num, img) # 输入帧号和图片信息
            if frame_num ==2000:
                return
        cap.release()
if __name__ == '__main__':
    capture()
using avdec_h264
using nvv4l2decoder
please help me solve this problem,thank you
We don’t have DeepStream 7.2 version.
sorry, it is version 7.1
Your python script works well in my Orin NX board. The only difference is that the JetPack version is 6.1
**There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks**
