Nvv4l2decoder is changing aspect ratio
• Hardware Platform (Jetson / GPU) Tesla T4
• DeepStream Version 5.1
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470.57.02
• Issue Type( questions, new requirements, bugs) bug
We discovered that the following pipeline is changing the resolution and aspect ratio of input video:
gst-launch-1.0 rtspsrc location=rtsp://  ! queue ! rtph264depay ! nvv4l2decoder ! nvv4l2h264enc ! h264parse ! splitmuxsink
If the input video is 2688x1520 then the output is the same. However in case of 848x480 (16:9) the output is 640x480 (4:3) and the video is extended vertically. This is a huge problem for us because we are running nvinfer on this video.
I was trying caps before nvv4l2decoder but it didn’t change the result.
I don’t see any plugin change the resolution in your pipeline. Do you mean loss pixel aspect ratio information?
No I mean the output video is squeezed.
If I use:
gst-launch-1.0 rtspsrc location=rtsp://  ! queue ! rtph264depay ! h264parse ! splitmuxsink
On the same stream the output is 848x480.
with nvv4l2decoder ! nvv4l2h264enc I got 640x480 that is squeezed
Suppose video encoder/decoder shouldn’t change resolution. Can you add gst-launch-1.0 -v rtspsrc … to show the caps of the pipeline?
Sorry. Issue was on my side I didn’t see that camera has:
Width: 640
Height: 480
Pixel aspect ratio: 126/95
That’s why pure gstreamer pipeline was producing 848x640 resolution and deepstrem was producing 640x480.
Thanks for your help.
