• Hardware Platform (Jetson / GPU) Tesla T4
• DeepStream Version 5.1 and 6.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 470.57.02
• Issue Type( questions, new requirements, bugs) Bug
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) As below
We are experiencing an issue while reading from the rtsp source. The pipeline can be simplified to:
gst-launch-1.0 rtspsrc location=rtsp:// ! queue ! rtph264depay ! nvv4l2decoder ! nvv4l2h264enc ! h264parse ! splitmuxsink
After a few minutes on the output video, we observe a loop of a few frames or a few frames are correct and then a few frames are from 4-5 minutes before.
Generally, we are using nvinfer element in this pipeline. However, the issue is visible in this simplified pipeline.
When we run it on GST_DEBUG=3 we get the following warnings in the output:
0:00:05.879711476 63 0x558a1d1388a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1066:gst_v4l2_buffer_pool_start:<nvv4l2h264enc0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:05.879829557 63 0x558a1d1388a0 WARN v4l2videodec gstv4l2videodec.c:1673:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:06.252140749 63 0x7f7ec0042140 WARN v4l2bufferpool gstv4l2bufferpool.c:1513:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
We also tried using uridecode but the issue is the same.
