Read RTSP give the output when used GPU decoder nvv4l2decoder stuck in loop at certain timestamp forever
• Hardware Platform (/ GPU)
• DeepStream Version: 6.0.1
• Issue Type(bugs)
I run the bellow pipeline: and get output video sink loop in the certain timestamp forver. What is the root cause of this issue?
This pipeline auto choose the decoder is nvv4l2decoder
gst-launch-1.0 rtspsrc location="rtsp://URI" protocols=4 short-header=1 ! decodebin ! queue ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! matroskamux ! filesink  location=nvv4l2dec_gpu_loop.mp4
But I tried the pipeline with CPU decoder without the loop issue:
gst-launch-1.0 rtspsrc location="rtspt://URI" protocols=tcp short-header=1 ! rtph264depay ! h264parse ! avdec_h264 ! nvvideoconvert ! nvv4l2h264enc ! h264parse ! matroskamux ! filesink  location=out_cpu.mp4
This is output have the loop issue. Could you Nvidia developer check the bugs and let me know what is the root cause?
test_cam74.log (49.6 MB)
Video spec:
Video: h264 (High) yuv420p(tv progressive) 1280x960 5 fps 5 tbr 90k tbn 10 tbc
You can try to update the deepstream to 6.1.1. It seems like the topic below:
https://forums.developer.nvidia.com/t/nvv4l2decoder-breaks-on-some-h-264-streams/213827
Thank you could you give me the root cause or release note for this issues? @yuweiw
@yuweiw Incase we could not update the version deepstream. Could we know the root cause and have workaround with it?
Does it necessary need to modified the nvv4l2decoder to get fix?
Yes, it needs to modify the nvv4l2decoder. The root cause related to the compatibility between h264 protocols and nvv4l2decoder lib. So it’s hard to provide the workround.
