I am trying to measure the encoder latencies with streaming and file based transcoding use-cases and observed that nvv4l2h265enc encoder latency is ~13 msec with streaming pipeline and `~48msec with file-based pipeline.
I am using below pipelines.
Streaming pipeline:
GST_DEBUG=“GST_TRACER:7” GST_TRACERS=“interlatency” GST_DEBUG_FILE=udpsrc_nvv4l2decoder_nvv4l2h265enc_pl4_fakesink.log
gst-launch-1.0 udpsrc port=50000 buffer-size=2000000 caps=“application/x-rtp , media=video, clock-rate=90000, payload=96, encoding-name=H264”
! rtpjitterbuffer
! rtph264depay
! nvv4l2decoder enable-max-performance=1 disable-dpb=true
! nvv4l2h265enc preset-level=4 MeasureEncoderLatency=1 maxperf-enable=1
! fakesink
File-based pipeline:
gst-launch-1.0 filesrc location=AIR_1080p30_nv12.h264
! h264parse
! nvv4l2h265enc preset-level=1 MeasureEncoderLatency=1 maxperf-enable=1
! fakesink
I have attached the log files for latencies.
What could be the reason for latency discrepancy ?
NOTE: I am seeing same latency numbers with streaming and file based, if I use preset-level=1.
Thanks for your help.
Best Regards,
Damoder
filesrc_nvv4l2decoder_nvv4l2h265enc_pl4_fakesink_MeasureEncoderLatency.log (17.4 KB)
udpsrc_nvv4l2decoder_nvv4l2h265enc_pl4_fakesink_MeasureEncoderLatency.log (125.6 KB)
