Nvvideoconvert on GPU instead of VIC
Hi, i have a deepstream pipeline running on L4T 36.3 on Jetson Orin Nx device. The pipeline makes use of nvvideoconvert deepstream gst plugin which by default use VIC. My project requires running the pipeline in a VM which unfortunately could only have GPU but not VIC passed through. I try setting nvvideoconvert property compute-hw=1 to force it to use GPU instead of VIC by default but got this err:
type or paste code here/dvs/git/dirty/git-master_linux/nvutils/nvbufsurftransform/nvbufsurftransform.cpp:3869: => Transformation Failed -1
0:00:00.260433929  1576 0xffff6c000e40 ERROR         nvvideoconvert gstnvvideoconvert.c:4235:gst_nvvideoconvert_transform: buffer transform failed
0:00:00.260550091  1576 0xffff6c000e40 WARN                 basesrc gstbasesrc.c:3127:gst_base_src_loop:<source> error: Internal data stream error.
0:00:00.260566187  1576 0xffff6c000e40 WARN                 basesrc gstbasesrc.c:3127:gst_base_src_loop:<source> error: streaming stopped, reason error (-5)
Error: gst-stream-error-quark: Internal data stream error. (1): ../libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:source:
I am wondering if I did anything wrong here or is it possible to use GPU with nvvideoconvert ?
Hi @tohai9402
Could you please share your pipeline?
Regards!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
@tohai9402
• DeepStream Version
• TensorRT Version
