I’m trying to follow the instructions for setting up cross compiling. Setting Up Cross-Platform Support
Follow the instructions “To clone a Jetson device and flash” under Basic Flashing Procedures in the Jetson Linux Driver Package Developer Guide to clone the target rootfs.
I’ve tried several times now but, the clone command always fails.
Am I doing something wrong? Or, is making a clone via USB a process that is so time consuming and difficult that it often fails?
Could I make the clone a different way given that this is a dev kit and the file system is on an SD card?
My host is Ubuntu 18.04. I’m installing JetPack 4.5.1.
I used SDK Manager to flash the NX dev kit. After that I updated the NX and installed various packages that we use.
I’ve seen Xavier Cloning but it is a very long and complicated topic, so perhaps I’ve missed something. (I thought I might try snarky’s suggestion for cloning not in recovery mode next.)
To make the clone I’m doing:
sudo ./flash.sh -r -k APP -G clone.img jetson-xavier-nx-devkit mmcblk0p1 |tee clone-log.txt
./flash.sh
runs for sometime. When it finishes it leaves clone.img
and clone.img.raw
but I don’t think they are correct clones because there is an error message and clone.img.raw
is not mountable.
Each time I’ve tried clone.img.raw
has a slightly different size.
Does Error: Return value 14
means anything to anyone?
Summary of transcript:
v4@ubuntu-18v4-sdkmgr:~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra$ sudo ./flash.sh -r -k APP -G clone.img jetson-xavier-nx-devkit mmcblk0p1 |tee clone-log.txt
[sudo] password for v4:
# L4T BSP Information:
# R32 , REVISION: 5.1
# Target Board Information:
# Name: jetson-xavier-nx-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/v4/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/v4/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0032 ] Generating RCM messages
[ 0.0042 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/v4/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
9.3420 ] tegradevflash_v2 --read APP /home/v4/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/clone2.img
[ 9.3444 ] Bootloader version 01.00.0000
[ 9.3902 ] 000000000d0f010e: t read %lu bytes from partition %s.4%
[ 4281.7290 ]
[ 4281.7290 ]
Command tegradevflash_v2 --read APP /home/v4/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra/clone2.img
*** The [APP] has been read successfully. ***
Converting RAW image to Sparse image... v4@ubuntu-18v4-sdkmgr:~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_XAVIER_NX_DEVKIT/Linux_for_Tegra$ ls -l clone.img clone.img.raw
-rwxr-xr-x 1 root root 18042134652 Dec 14 18:54 clone.img
-rw-r--r-- 1 root root 36069965824 Dec 14 18:52 clone.img.raw
