@vidyas
Thank you for follwing up
from dev:
"yes, correct
The allocated buffer is in CMA region in case of NULL pointer
The allocation is from somewhere else in case, that I use dev. I don’t know what memory region is used in this case. I am able to read and write the region from kernel driver, but I am unable to access this region from userspace.
The access works in case, that I use NULL pointer. Then I am able to access it from userspace.
The devs discussed with other SW engineer, that wrote the driver, his opinion is, that NULL pointer in PCIe driver could be used too.
“I am using customized kernel now. I compiled kernel with larger CMA buffer. Default size was 64MB. I am using 256MB now. The driver allocates 128MB.”
Update from the dev:
“I am testing PCIe driver with NULL pointer now.
I am able to read the data from buffer. I wrote data in kernel driver and I was able to read data by SW application from userspace. So it seems, that the previous issue has been solved (the issue was, that I was not able to access the data in memory region allocated by kernel driver)
But there is one more issue. It is connected to SMMU. It seems, that FPGA is unable to transfer all data to this memory buffer. The dmesg log:”
[ 63.804990] txlink flInit(), built at Nov 18 2020 22:21:47
[ 63.805205] pcieProbe(dev = 0xffffffc1f4c61000, pciid = 0xffffff8000f79b38)
[ 63.805211] pcieProbe() ape = 0xffffffc1c0ee0180
[ 63.805244] txlink 0005:01:00.0: enabling device (0000 -> 0002)
[ 63.805477] Using a 64-bit DMA mask.
[ 63.805674] BAR mapped at barBA = 0x00000000, barVA = 0xffffff800dd0e000, barMinLen = 0x00000100, barLength = 0x02000000
[ 63.805679] Request size 134213632
[ 63.832182] Allocated DMA buffer (virt: ffffffc037200000; bus: 00000000b7200000).
[ 63.832198] pcieProbe() successful.
[ 87.219708] cdevOpen() dev=0xffffffc1c0ee0180
[ 87.219736] cdevMmap() dev=0xffffffc1c0ee0180
[ 87.220019] cdevMmap() dev=0xffffffc1c0ee0180
[ 87.220029] cdevMMap dev->bufBA: 0x b7200000,PAGE_SHIFT 0xc
[ 87.226509] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb7200000, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.233430] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb72a87c0, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.240042] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb738ab40, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.247724] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb74b3340, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.254161] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb757c340, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.261506] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb766e800, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.267594] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb7762780, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.274153] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb784bc80, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.280791] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb7924a00, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.287623] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0xb7a1c980, fsynr=0x280011, cb=1, sid=91(0x5b - PCIE5), pgd=0, pud=0, pmd=0, pte=0
[ 87.374571] mc-err: vpr base=0:c6000000, size=20, ctrl=3, override:(a01a8340, fcee10c1, 1, 0)
[ 87.374760] mc-err: (255) csw_pcie5w: MC request violates VPR requirements
[ 87.374922] mc-err: status = 0x0ff740e3; addr = 0xffffffff00; hi_adr_reg=008
[ 87.375060] mc-err: secure: yes, access-type: write
[ 87.375163] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
The issue is this:
I tried to disable SMMU using following changes (found in NVIDIA forum):
--- a/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi
+++ b/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi
@@ -867,13 +867,6 @@
pinctrl-0 = <&pex_rst_c5_out_state>;
pinctrl-1 = <&clkreq_c5_bi_dir_state>;
- iommus = <&smmu TEGRA_SID_PCIE5>;
- dma-coherent;
-#if LINUX_VERSION >= 414
- iommu-map = <0x0 &smmu TEGRA_SID_PCIE5 0x1000>;
- iommu-map-mask = <0x0>;
-#endif
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 0>;
interrupt-map = <0 0 0 0 &intc 0 53 0x04>;
--- a/drivers/iommu/arm-smmu-t19x.c
+++ b/drivers/iommu/arm-smmu-t19x.c
@@ -2535,7 +2535,10 @@ static void arm_smmu_device_reset(struct arm_smmu_device *smmu)
reg = readl_relaxed(ARM_SMMU_GR0_NS(smmu) + ARM_SMMU_GR0_sCR0);
/* Enable fault reporting */
- reg |= (sCR0_GFRE | sCR0_GFIE | sCR0_GCFGFRE | sCR0_GCFGFIE | sCR0_USFCFG);
+ reg |= (sCR0_GFRE | sCR0_GFIE | sCR0_GCFGFRE | sCR0_GCFGFIE);
+ /* Disable Unidentified stream fault reporting */
+ reg &= ~(sCR0_USFCFG);
/* Disable TLB broadcasting. */
reg |= (sCR0_VMIDPNE | sCR0_PTM);
Update from dev:
“pcie smmu issue
I am going to try tegra194-memcfg-sw-override.cfg modification.”
