Objects not counted sometimes when line is crossed
**• Hardware Platform ** dGPU
• DeepStream Version 6.0
• TensorRT Version 8.2.1
• NVIDIA GPU Driver Version (valid for GPU only) GTX 1070
I am using deepstream python application. I have an issue of object are not counted even when line is clearly crossed, detection is stable, tracking id doesn’t change.
I have tried different modes (loose, balanced, strict) but always issue persists.
Only when I changed the line just slightly then objects are counted.
could you please tell me why this happens? anyway how can I fix it?
Sorry for the late response, is this still an issue to support? Thanks
@kayccc Yes, I’m still having this issue, I’ve sent you sample video in pm to understand better the issue
Can you share more? such as command line you run or video to show the issue?
@kesong I’ve sent sample videos on pm, please check them
I’m using a custom app that’s built on top of this deepstream_python_apps/apps/deepstream-nvdsanalytics at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
with some modifications, different pgie, no secondary classifers, disable obj counting
command line is the same
Is it possible to reproduce with DS samples?
I don’t think it’s possible, my model was trained on a specific data.
@kesong I just did, and the issue remains
Can you share reproduce step for reproduce the issue in DS sample?
Hi radoinekadari,
Could you please provide config files and any other file to reproduce this issue?
Thank you!
