OC3 raised at current lower than critical
They are detected by HW and we can only monitor the count instead of the value.
You can refer to Jetson Orin NX power management parameters - #13 by KevinFFF for details.
Normally, the OC throttling will happen shortly and recover soon. We would suggest creating a custom power mode configuration to reduce the occurrence of throttling. You should adjust them to get the balance between the power and the performance.
