Offline install cuda and nvidia driver
My CentOS 7 environment is isolated from any internet connection.
I tried to pre-downloaded .rpm file and install it, however it still require internet connection.
Do anyone know how to install cuda and nvidia driver without internet?
YO@YOYO[/Data/]18:19:26 $ md5sum cuda-repo-rhel7-8-0-local-cublas-performance-update-8.0.61-1.x86_64.rpm
9444edc08d8e2726a89e013d51d985c5  cuda-repo-rhel7-8-0-local-cublas-performance-update-8.0.61-1.x86_64.rpm
YO@YOYO[/Data/]18:20:18 $ sudo rpm --install cuda-repo-rhel7-8-0-local-ga2-8.0.61-1.x86_64.rpm
warning: cuda-repo-rhel7-8-0-local-ga2-8.0.61-1.x86_64.rpm: Header V3 RSA/SHA512 Signature, key ID 7fa2af80: NOKEY
You have mail in /var/spool/mail/YO
YO@YOYO[/Data/]18:21:33 $ sudo yum clean expire-cache
Loaded plugins: fastestmirror, langpacks
Cleaning repos: base bintray--sbt-rpm cuda-8-0-local-ga2 download.mono-project.com_repo_centos_ elrepo epel extras media updates
0 metadata files removed
YO@YOYO[/Data/]18:25:24 $ sudo yum install cuda
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was
14: curl#7 - "Failed to connect to 2604:1580:fe02:2::10: Network is unreachable"
One of the configured repositories failed (Unknown),
 and yum doesn't have enough cached data to continue. At this point the only
 safe thing yum can do is fail. There are a few ways to work "fix" this:
     1. Contact the upstream for the repository and get them to fix the problem.
     2. Reconfigure the baseurl/etc. for the repository, to point to a working
        upstream. This is most often useful if you are using a newer
        distribution release than is supported by the repository (and the
        packages for the previous distribution release still work).
     3. Disable the repository, so yum won't use it by default. Yum will then
        just ignore the repository until you permanently enable it again or use
        --enablerepo for temporary usage:
            yum-config-manager --disable <repoid>
     4. Configure the failing repository to be skipped, if it is unavailable.
        Note that yum will try to contact the repo. when it runs most commands,
        so will have to try and fail each time (and thus. yum will be be much
        slower). If it is a very temporary problem though, this is often a nice
        compromise:
            yum-config-manager --save --setopt=<repoid>.skip_if_unavailable=true
Cannot find a valid baseurl for repo: base/7/x86_64
Use the runfile installer method.
It is covered in the linux install guide. And runfile installers are available for CUDA and driver installs.
