In the kernel with the real-time patch applied, peripherals such as the keyboard and mouse can be powered on, and it is possible to log in and use them through a serial port. In the kernel without the real-time patch, the system can boot up normally.
The steps I took to compile the real-time system kernel are as follows:
(1) Obtain the Jetson Linux BSP package, rootfs package, and kernel source package from the following website.
jetson-linux-r3531
(2) Extract the downloaded resources on the host machine using the following commands:
sudo tar xf Jetson_Linux_R35.3.1_aarch64.tbz2 -C ${MyWorkSpace}/nvidia/
sudo tar xf Tegra_Linux_Sample-Root-Filesystem_R35.3.1_aarch64.tbz2 -C \ ${MyWorkSpace}/nvidia/Linux_for_Tegra/rootfs/
sudo tar xf public_sources.tbz2 -C ${MyWorkSpace}/nvidia/source/
(3) Compile the real-time kernel:
su
cd Linux_for_Tegra/source/public
tar -xjf kernel_src.tbz2
sudo apt-get install build-essential bc
sudo tar -xvf gcc-linaro-7.3.1-2018.05-i686_aarch64-linux-gnu.tar.xz -C /opt
export PATH=/opt/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/:$PATH
export LOCALVERSION=-tegra
export CROSS_COMPILE=aarch64-linux-gnu-
cd kernel/kernel-5.10/
scripts/rt-patch.sh apply-patches
make ARCH=arm64 tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j8
sudo make ARCH=arm64 O=$TEGRA_KERNEL_OUT modules_install
INSTALL_MOD_PATH=${MyWorkSpace}/nvidia/Linux_for_Tegra/rootfs/
cp arch/arm64/boot/Image ${MyWorkSpace}/nvidia/Linux_for_Tegra/kernel/
cp arch/arm64/boot/dts/nvidia/* ${MyWorkSpace}/nvidia/Linux_for_Tegra/kernel/dtb/
(4) Flash the system to Jetson Orin NX.
cd ${MyWorkSpace}/nvidia/Linux_for_Tegra/
./apply_binaries.sh
cd tools
./l4t_create_default_user.sh -n nvidia -p nvidia
cd …/
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1
-c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml”
–showlogs --network usb0 p3509-a02+p3767-0000 internal
Following the above method, after powering on, the HDMI display shows for 3 seconds, and then the HDMI display turns off.
However, data can be received through the serial port. The boot information printed on the serial port is as follows:
20230530_0917_JNOlog.txt (88.1 KB)
Are there any errors or omissions in the above steps?
