Hi all,
The following project installs boot from SSD on the Xavier AGX, Xavier NX or Nano simply with out command from Jetpack 4.6.
https://github.com/hcfman/sbts-boot-from-SSD
It also allows you to run with a read-only OS mount (With memory overlay file system), though if you can going to use this mode you will need to disable docker.service and docker.socket first as docker doesn’t run on top of an overlay file system.
Consider this a pre-release as shortly I will announce some new projects but I’m still preparing YouTube videos and documentation.
Cheers,
Kim Hendrikse
