Make sure all your settings are set to the stock correct setting in the bios. Also make sure there is significant voltage on your Fsb and Cpu Vcore. Also i know that in the 790i bios there is an option to select weather core 0 core 1 core 2 and core 3 or either on or off. Just speaking from expeience i know that i overclocked my q6600 and if there wasn’t enough voltage sometimes the bios would boot using only one Core from my cpu… Thats just my little tid bit… hope it helps.
Mainly there on auto, or a setting made by the motherboard. I would just either pull out a manual, go to the manufacture site, or google your cpu name and the put “stock voltage”.
Hmmm, you’re past the point of things I’ve tried. My Phenom 9950 is showing up as four cores, and I didn’t have to set anything in particular in the BIOS.
The above was happening with a Tesla C1060 card plugged into the 3rd PCI-E slot out of the 4 available, so that the card will be far from the CPU to get less affected by its heat and to still be in a 16x slot.
I also downgraded the CPU to an AMD 9850.
After removing the card, the system boots, but pauses for about 5 second after
Memory for crash kernel (0x0 to 0x0) not within permissible range.
‘uname -a’ gives:
uname -a
Linux localhost.localdomain 2.6.18-128.1.1.el5 #1 SMP Mon Jan 26 13:58:24 EST 2009 x86_64 x86_64 x86_64 GNU/Linux
The AMD 9850 has all its four cores recognized now, but they are clocked at 1.3 GHz, as opposed to 2.5 GHz that they should be clocked at:
more proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 16
model : 2
model name : AMD Phenom™ 9850 Quad-Core Processor
stepping : 3
cpu MHz : 1300.000
cache size : 512 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 4
apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov
cat /proc/cpuinfo while a CPU process is running. If you have a multithreaded program, you should see more than one core ramping up the clock ( each core has its own clock).
Sorry, I am not involved with motherboard/card testing.
As has already been said. This is normal. The OS will ramp the clock down to save power when it isn’t needed. Run cpuburn or something and watch the clocks go back up.
Nope. But you might try a linux distrubution with a more modern kernel. Say, the latest version of Fedora that supports CUDA. RHEL runs positively ancient versions of the kernel which might lead to issues with the latest and greatest hardware.
I have had similar issues with Kubuntu 8.04 install kpowersave and then start it and set it to performance. That should bring your clock speed up to 3000.
