Onnx and trt output has a large gap
my onnx model output and converted trt model output has large gap
it seems not allowing me to attach onnx model file
trt 8.2 jp 4.6
./trtexec --onnx=*.onnx --saveEngine=*.trt --workspace=4096 --fp16 --verbose
model link nv_sample_model - Google Drive
Dear @QQQQ,
May I know the used platform? If it is Jetson AGX Xavier, can you check with jetpack 5.1.3? Also, could you share repro code and steps?
We can not try a different version of jp, since it’s already in production. I already shared the model, please use that model with random input and you will find the gap between them easily. And it is under AGX Xavier.
def get_onnx_output(path, a):
    ort_sess = ort.InferenceSession(path)
    input_name = ort_sess.get_inputs()[0].name
    output_names = [i.name for i in ort_sess.get_outputs()]
    output = ort_sess.run(output_names, {
        input_name: a
    return output
class HostDeviceMem(object):
    def __init__(self, host_mem, device_mem):
        self.host = host_mem
        self.device = device_mem
    def __str__(self):
        return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
    def __repr__(self):
        return self.__str__()
class TrtModel:
    def __init__(self, engine_path, input_shape=[512,512], batch_size=1, max_batch_size=1, dtype=np.float32):
        self.input_shape = input_shape
        self.engine_path = engine_path
        self.batch_size = batch_size
        self.dtype = dtype
        self.logger = trt.Logger(trt.Logger.WARNING)
        self.runtime = trt.Runtime(self.logger)
        self.engine = self.load_engine(self.runtime, self.engine_path)
        self.max_batch_size = max_batch_size
        self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
        self.context = self.engine.create_execution_context()
        # self.context.set_binding_shape(batch_size, (1, 512, 512))
    @staticmethod
    def load_engine(trt_runtime, engine_path):
        trt.init_libnvinfer_plugins(None, "")
        with open(engine_path, 'rb') as f:
            engine_data = f.read()
        engine = trt_runtime.deserialize_cuda_engine(engine_data)
        return engine
    def allocate_buffers(self):
        inputs = []
        outputs = []
        bindings = []
        stream = cuda.Stream()
        for binding in self.engine:
            size = trt.volume(self.engine.get_binding_shape(binding))
            if self.engine.get_binding_shape(binding)[0] == -1:
                size = -1 * size * self.batch_size
            host_mem = cuda.pagelocked_empty(size, self.dtype)
            device_mem = cuda.mem_alloc(host_mem.nbytes)
            bindings.append(int(device_mem))
            if self.engine.binding_is_input(binding):
                inputs.append(HostDeviceMem(host_mem, device_mem))
            else:
                outputs.append(HostDeviceMem(host_mem, device_mem))
        return inputs, outputs, bindings, stream
    def __call__(self, x: np.ndarray, batch_size=1):
        x = x.astype(self.dtype)
        np.copyto(self.inputs[0].host, x.ravel())
        for inp in self.inputs:
            cuda.memcpy_htod_async(inp.device, inp.host, self.stream)
        self.context.execute_async(
            batch_size=batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
        for out in self.outputs:
            cuda.memcpy_dtoh_async(out.host, out.device, self.stream)
        self.stream.synchronize()
        return [out.host.reshape(batch_size, -1) for out in self.outputs]
class TensorRTInfer:
    Implements inference for the TensorRT engine.
    def __init__(self, engine_path, batch_size=4):
        :param engine_path: The path to the serialized engine to load from disk.
        # Load TRT engine
        self.logger = trt.Logger(trt.Logger.ERROR)
        with open(engine_path, "rb") as f, trt.Runtime(self.logger) as runtime:
            self.engine = runtime.deserialize_cuda_engine(f.read())
        assert self.engine
        assert self.context
        # Setup I/O bindings
        self.inputs = []
        self.outputs = []
        self.allocations = []
        for i in range(self.engine.num_bindings):
            is_input = False
            if self.engine.binding_is_input(i):
                is_input = True
            name = self.engine.get_binding_name(i)
            dtype = self.engine.get_binding_dtype(i)
            shape = self.engine.get_binding_shape(i)
            size = np.dtype(trt.nptype(dtype)).itemsize
            for s in shape:
                size *= s
            if size < 0:
                size = size * -1
            allocation = cuda.mem_alloc(size)
            binding = {
                'index': i,
                'name': name,
                'dtype': np.dtype(trt.nptype(dtype)),
                'shape': list(shape),
                'allocation': allocation,
            self.allocations.append(allocation)
                self.inputs.append(binding)
            else:
                self.outputs.append(binding)
        assert self.batch_size > 0
        assert len(self.inputs) > 0
        assert len(self.outputs) > 0
        assert len(self.allocations) > 0
    def input_spec(self):
        return self.inputs[0]['shape'], self.inputs[0]['dtype']
    def output_spec(self):
        return self.outputs[0]['shape'], self.outputs[0]['dtype']
    def infer(self, batch, top=1):
        # Prepare the output data
        output = np.zeros(*self.output_spec())
        # Process I/O and execute the network
        cuda.memcpy_htod(self.inputs[0]['allocation'], np.ascontiguousarray(batch))
        self.context.execute_v2(self.allocations)
        cuda.memcpy_dtoh(output, self.outputs[0]['allocation'])
        return output
a = np.random.random((1, 1, 512, 512)).astype(np.float32)
@SivaRamaKrishnaNV any updates?
Dear @QQQQ ,
Just checking if it could be due to fp16 precision. How much % of difference is noticed on average? Also, what is the % of effect on the final outcome?
Did you try with fp32 and noticed the same? Also, could you please share complete repro code for a quick test?
# -*-coding: utf-8 -*-
import os
import pathlib
import sys
# import cv2
import onnxruntime as ort
import tensorrt as trt
import argparse
# export LD_LIBRARY_PATH=/usr/local/lib:$LD_LIBRARY_PATH
# pip install numpy==1.19.4
## trt python
import numpy as np
import pycuda.driver as cuda
import pycuda.autoinit
        input_name: a
    return output
        # Load TRT engine
        assert self.engine
        assert self.context
        self.inputs = []
        self.outputs = []
            is_input = False
                is_input = True
            for s in shape:
                size *= s
            if size < 0:
                size = size * -1
            binding = {
                'index': i,
                'name': name,
            else:
        return output
op_onnx = get_onnx_output("onnx", a)
trt_engine = TensorRTInfer("trt")
op_trt = trt_engine.infer(a)
please, i already shared the code it’s actually quite obvious, the answer you are asking is actually already there.
I am pretty sure i already provide all the things needed would you please at least try download it and run it? It shouldn’t be like this, waiting for a week and still asking for the same thing already provided.
@SivaRamaKrishnaNV
I verified the issue with your model on Jetpack 5.1.3 (Last release for Jetson Xavier) . When using FP32 precision, the onnx and tensorrt output blob matches. But when TRT FP 16 engine is used for inference, noticed < 0.2 % difference(compared to onnx output blob) in values in output blob. May I know how much difference in the final output task prediction is noticed in your case due to the difference in output blob?
