Description
I have an onnx model, whose output has beed verified to be almost identical with my original PyTorch model.
After I convert it to tensorrt engine, the output changes too much. I don’t know if there is any tool I can use to debug and locate the place where error produced between onnx and trt?
Environment
nvidia docker container 22.12
Relevant Files
Here is the onnx model: https://cloud.tsinghua.edu.cn/f/8e1a7623952946c7bb76/?dl=1
Steps To Reproduce
Use this script to reproduce:
import os
import torch
import torch.nn as nn
import tensorrt as trt
TRT_LOGGER = trt.Logger()
trt.init_libnvinfer_plugins(TRT_LOGGER, '')
def load_engine(engine_file_path):
assert os.path.exists(engine_file_path)
print("Reading engine from file {}".format(engine_file_path))
with open(engine_file_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
return runtime.deserialize_cuda_engine(f.read())
from torch.testing._internal.common_utils import numpy_to_torch_dtype_dict
def get_trt_stuff(engine_path):
engine = load_engine(engine_path)
context = engine.create_execution_context()
inputs_dict = {}
outputs_dict = {}
bindings = []
for binding in engine:
binding_idx = engine.get_binding_index(binding)
# size = trt.volume(context.get_binding_shape(binding_idx))
dtype = trt.nptype(engine.get_binding_dtype(binding))
shape = tuple(context.get_binding_shape(binding_idx))
if engine.binding_is_input(binding):
inputs_dict[binding] = torch.empty(*shape, dtype=numpy_to_torch_dtype_dict[dtype], device='cuda')
bindings.append(int(inputs_dict[binding].data_ptr()))
else:
outputs_dict[binding] = torch.empty(*shape, dtype=numpy_to_torch_dtype_dict[dtype], device='cuda')
bindings.append(int(outputs_dict[binding].data_ptr()))
return context, bindings, inputs_dict, outputs_dict
def run_trt(context, bindings, stream=None):
if stream is None:
stream = torch.cuda.default_stream()
state = context.execute_async_v2(bindings=bindings, stream_handle=stream.cuda_stream)
stream.synchronize()
return state
class TRTModule(nn.Module):
def __init__(self, engine_path):
super().__init__()
self.context, self.bindings, self.inputs_dict, self.outputs_dict = get_trt_stuff(engine_path)
def forward(self, *inputs, **kw_args):
device = 'cpu'
for i, inp in enumerate(inputs):
self.inputs_dict['input_{}'.format(i)].copy_(inp)
device = inp.device
shift = len(inputs)
for k in kw_args:
self.inputs_dict['input_{}'.format(shift)].copy_(kw_args[k])
shift += 1
state = run_trt(self.context, self.bindings)
if not state:
raise Exception("trt engine execution failed")
outputs = []
for i in range(len(self.outputs_dict)):
outputs.append(self.outputs_dict['output_{}'.format(i)].cpu().to(device))
if len(outputs) == 1:
outputs = outputs[0]
return outputs
import onnxruntime as ort
def get_ort_stuff(onnx_path, providers):
return ort.InferenceSession(onnx_path, providers=providers)
class ORTModule(nn.Module):
def __init__(self, onnx_path, providers=['CUDAExecutionProvider', 'CPUExecutionProvider']):
super().__init__()
self.sess = get_ort_stuff(onnx_path, providers)
device = 'cpu'
for inp in inputs:
device = inp.device
for k in kw_args:
device = kw_args[k].device
inputs_dict = {'input_{}'.format(i):x.cpu().numpy() if isinstance(x, torch.Tensor) else x for i, x in enumerate(inputs)}
shift = len(inputs_dict)
for k in kw_args:
inputs_dict['input_{}'.format(shift)] = kw_args[k].cpu().numpy()
shift += 1
outputs = self.sess.run(None, inputs_dict)
outputs = [torch.from_numpy(x).to(device) for x in outputs]
return outputs
input_0 = torch.randn(2, 3, 256, 256, dtype=torch.float32).cuda()
input_1 = torch.tensor([1, 3], dtype=torch.int32).cuda()
input_2 = torch.randn(2, 81, 640, dtype=torch.float32).cuda()
ort = ORTModule('onnx/EfficientUNetModel_.onnx', providers=['CUDAExecutionProvider', 'CPUExecutionProvider'])
os.system('trtexec --onnx=onnx/EfficientUNetModel_.onnx --saveEngine=onnx/EfficientUNetModel_.trt --fp16 --buildOnly')
trt = TRTModule('onnx/EfficientUNetModel_.trt')
out_ort = ort(input_0, input_1, input_2)
out_trt = trt(input_0, input_1, input_2)
print((out_ort-out_trt).abs().max().item())
Before run it, you should pip install onnxruntime-gpu.
It shows the absolute error is ~4.6 that large.
Also refer to Onnx output differs largely to TRT engine output
