Onnx to tensorrt problem
i am using trt 8.0 to convert onnx model to trt model, but an error below occurs:
This error indicates that the padding value of my pad_119 node is not 0, but from Netron I can see that the constant_value is 0
here is my “Pad_119” node looks like:
Environment
TensorRT Version: 8.0.1.6
Can you please try using TRT 8.2 onwards
If not, please share your onnx model with us.
solved, tensorrt 8.0.1 does not support padding with non-zero values, changing it to concat node in onnx and convert to trt will work
