Hello, Is there any alternative to implement reflect padding in tensorRT. I can’t replace reflect padding to constant padding. Currently I am getting below error while converting onnx model to tensorRT.
ERROR: builtin_op_importers.cpp:2191 In function importPad:
[8] Assertion failed: mode == "constant" && value == 0.f && "This version of TensorRT only supports constant 0 padding!"
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
