getting following error: on tx2. if it can be solved by inc the RAM how can I do it ?
2018-03-28 14:13:54.116758: W tensorflow/core/framework/op_kernel.cc:1192] Internal: WhereOp: Could not launch cub::DeviceSelect::Flagged to copy indices out, status: too many resources requested for launch
2018-03-28 14:13:54.117907: W tensorflow/core/framework/op_kernel.cc:1192] Internal: WhereOp: Could not launch cub::DeviceSelect::Flagged to copy indices out, status: too many resources requested for launch
[[Node: SecondStagePostprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/FilterGreaterThan/Where = Where_device="/job:localhost/replica:0/task:0/device:GPU:0"]]
2018-03-28 14:13:54.118051: W tensorflow/core/framework/op_kernel.cc:1192] Internal: WhereOp: Could not launch cub::DeviceSelect::Flagged to copy indices out, status: too many resources requested for launch
terminate called after throwing an instance of ‘std::out_of_range’
what(): vector::_M_range_check: __n (which is 0) >= this->size() (which is 0)
sudo ~/tegrastats output
RAM 5549/7851MB (lfb 212x4MB) SWAP 8/16384MB (cached 0MB) cpu
RAM 6498/7851MB (lfb 3x4MB) SWAP 29/16384MB (cached 1MB) cpu [54%@2032,76%@2034,95%@2034,49%@2030,61%@2029,60%@2031] EMC 26%@1866 APE 150 GR3D 7%@1300
RAM 6582/7851MB (lfb 2x4MB) SWAP 36/16384MB (cached 0MB) cpu [62%@2031,68%@2034,98%@2035,62%@2032,57%@2031,60%@2031] EMC 39%@1866 APE 150 GR3D 99%@1300
RAM 6581/7851MB (lfb 2x4MB) SWAP 36/16384MB (cached 0MB) cpu [7%@2033,100%@2035,98%@2035,11%@2032,10%@2031,7%@2031] EMC 43%@1866 APE 150 GR3D 99%@1300
RAM 5414/7851MB (lfb 192x4MB) SWAP 37/16384MB (cached 0MB) cpu [12%@2033,66%@2036,57%@2035,13%@2033,23%@2035,26%@2034] EMC 28%@1866 APE 150 GR3D 8%@1300
RAM 3575/7851MB (lfb 486x4MB) SWAP 37/16384MB (cached 0MB) cpu [5%@2022,1%@2035,9%@2036,3%@2034,6%@2034,15%@2033] EMC 16%@1866 APE 150 GR3D 0%@1300
RAM 3575/7851MB (lfb 486x4MB) SWAP 37/16384MB (cached 0MB) cpu [1%@2020,1%@2035,0%@2035,1%@2033,0%@2033,2%@2036] EMC 9%@1866 APE 150 GR3D 0%@1300
