Regarding the create clause in the data construct the OpenACC v2.0 specification says:
…On a data construct or compute construct, the data is allocated in device memory upon entry to the region, and deallocated upon exit from the region. …
This suggests that it should be enough to declare a pointer on the host and call the create clause on it to allocate memory on the accelerator. But, this clause only seem to work if the data on the host side is also allocated, regardless of the fact that the size of allocation is specified in the squared brackets. The code looks the following:
inline void adi_acc(float lambda, float *u, float *du, float *ax, float *bx, float *cx, int nx, int ny, int nz ...) {
int i, j, k;
int n = nx*ny*nz;
#pragma acc data present(u[n], du[n], ax[n], bx[n], cx[n])
#pragma acc kernels loop collapse(3) independent
for(k=0; k<NZ; k++) {
for(j=0; j<NY; j++) {
for(i=0; i<NX; i++) {
cuda_library_wrapper(u,du,ax,bx,cx);
int main(int argc, char* argv[]) {
float *h_u, *h_du, *h_ax, *h_bx, *h_cx;
int n = NX*NY*NZ;
h_u = (float *)malloc(sizeof(float)*n);
//h_du = (float *)malloc(sizeof(float)*n);
//h_ax = (float *)malloc(sizeof(float)*n);
//h_bx = (float *)malloc(sizeof(float)*n);
//h_cx = (float *)malloc(sizeof(float)*n);
acc_init(acc_device_nvidia);
acc_set_device_num(0,acc_device_nvidia);
#pragma acc data pcopy(h_u[n]) create(h_du[n], h_ax[n], h_bx[n], h_cx[n])
elapsed_time(&timer2);
for(it=0; it<iter; it++) {
adi_acc(lambda, h_u, h_du, h_ax, h_bx, h_cx, nx, ny, nz, ...);
elapsed_total = elapsed_time(&timer2);
free(h_u);
free(h_du);
free(h_ax);
free(h_bx);
free(h_cx);
acc_shutdown(acc_device_nvidia);
exit(0);
So, when the host memory allocation lines are put into comments, I get the following error message:
FATAL ERROR: variable data clause is partially present on the GPU: name=h_ax
file:/home/endre/workspace/adi/src/adi_acc_libtrid.c main line:285
where the line 285 is the one with the create() clause:
When I run the code with cuda-memcheck, It also reports error concerning CUDA Context. Although this error seems to be regardless of the create() clause:
========= Program hit error 201 on CUDA API call to cuCtxAttach
========= Saved host backtrace up to driver entry point at error
========= Host Frame:/usr/lib64/libcuda.so (cuCtxAttach + 0x182) [0xd9af2]
========= Host Frame:./adi_acc_libtrid [0x1a755]FATAL ERROR: variable data clause is partially present on the GPU: name=h_ax
========= ERROR SUMMARY: 1 error
Note: I link against an nvcc-compiled wrapper function.
Used config: Red Hat v6, PGI 14.1, NVIDIA K20c
The question is:
Is it really needed to allocate memory on the host as well?
Any help is much appreciated!
