Avoid reallocating memory on the GPU.
Hello.
I’m trying to parallelize a program using OpenACC (pgcc).
My program calls a certain function (let’s call it function1()) a lot of times. This function allways uses the same ammount of memory each time it’s called.
Assume tha function1() is something like:
void function1(){
#pragma acc data copyin(ArraysIn[sizeOfArrays]), copyout(ArrayOut[sizeOfArray])
#pragma acc kernels
for(){
    #pragma acc kernels
    for(){
        #pragma acc kernels
        for(){
            /*Do some work here*/
Since this function is called several times, each time I call it I’m allocating the arrays I need on the GPU. I want to allocate these arrays only once and reuse them so that I don’t need to keep spending time allocating again.
How can I do this, having in mind that the compiler can’t determine the size of the arrays automatically?
Will something like this work?
main{
#pragma acc data create(ArraysIn[sizeOfArrays], ArrayOut[sizeOfArray])
for(){
function1();
And then change function1() to:
void function1(){
#pragma acc update device(ArraysIn[sizeOfArrays])
#pragma acc kernels
for(){
    #pragma acc kernels
    for(){
        #pragma acc kernels
        for(){
#pragma acc update host(copyout(ArrayOut[sizeOfArray]))
Will this work? Will it work even if this call (#pragma acc data create(ArraysIn[sizeOfArrays], ArrayOut[sizeOfArray])) is made from some other function call before function1()?
Will this work?
This is the right idea. You just need to add a data region in function1 telling the runtime to go look-up where the array is on the device (via the “present” clause).
You can use the “update” in combination with the “present” clause. (Note that I made a few other small corrections)
void function1(ArraysIn, ArraysOut){
#pragma acc data present(ArraysIn[0:sizeOfArrays],ArraysOut[0:sizeOfArrays])
#pragma acc update device(ArraysIn[0:sizeOfArrays])
#pragma acc kernels
for(){
    for(){
        for(){
#pragma acc update host(copyout(ArrayOut[0:sizeOfArray]))
You use “pcreate” (present or create) instead of “present” if you don’t know if this routine is called from within another data region. With just “present”, you’d get a runtime error if the data isn’t already on the device. With “pcreate”, the arrays would be created if not found.
Hope this helps,
Mat
I’m sorry to bother you again with the same topic, but it took me some time to be able to actually test this and this doesn’t seem to work at all.
This compiles correctly but when I try to run it, I get the following:
FATAL ERROR: data in PRESENT clause was not found: name=clP
clP is one of the arrays I need to allocate on the GPU.
The problem here seems to be that the main function is in one .c file and function1 is in another .c file. Also, I don’t know if this has anything to do with it or not but function1 is not called exactly on the main function. Main calls functionA, funcitonA calls functionB and functionB calls function1.
This looks something like this:
void funtionB(){function1();}
void functionA(){functionB();}
int main(int argc, char* argv[]){
for(){funtionA();}
And function1 is what I mentioned previously.
What am I doing wrong here?
If needed I can post the actual code for these functions.
Hi JPMN,
You just need to add back in the outer data region surrounding the for loop in the main routine to have the arrays copied over to the device before “present” looks them up.
  • Mat
Hi.
First and foremost thank you for the quick reply :).
I’m not sure if I understant your answer though. There was a typo on the main function I presented last post, the actual function is:
#pragma acc data create(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats], clP[4*numChars*numGammaCats], tiPA[16*numGammaCats], clA[4*numChars*numGammaCats], clP[4*numChars*numGammaCats])
for(){funtionA();}
And then, on function1 I have the present clause followed by an update device clause to transfer the data into these arrays.
Are you saying that I need to have the data copied into the device before I can do the present clause? If that’s the case that would ruin this code because function1 always uses the same type of arrays with the same size but the data on the arrays are different from function call to function call.
It has to be allocated on the device, so using “create” is fine. Alternatively, you can use “present_or_copy” (or “pcopy”) instead of “present”. “pcopy” will look to see if the data’s already been allocated on the device, otherwise it’s allocated and copied over.
Note that the arrays in the “present” clause don’t have to be the same array each time function1 is called. Nor do the arrays need to start at the beginning. For example, you could create a large block of memory on the device and then pass pointers into this block and have present find the proper device data. So long as the entire array is on the device, “present” will allow it.
  • Mat
I understant all that, but the fact is that the present clause still doesn’t find the arrays I created earlier with the data create clause, I already had that clause in my code when I asked this question. With all those clauses I still get the error:
And I really don’t know why. I’ll post the actual code:
My main function is something like this:
int main(int argc, char * argv[]){
/*Other code here*/
int         numGammaCats=(&modelSettings[0])->numGammaCats, numChars=(&modelSettings[0])->numChars;
/*Other code here*/
#pragma acc data create(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats], clP[4*numChars*numGammaCats], tiPA[16*numGammaCats], clA[4*numChars*numGammaCats])
for (chn=0; chn<numLocalChains; chn++)
		curLnL[chn] = LogLike(chn);
		curLnPr[chn] = LogPrior(chn);
		for (i=0; i<numCurrentDivisions; i++)
			if (modelSettings[i].gibbsGamma == YES)
				curLnL[chn] += GibbsSampleGamma (chn, i, seed);
Where LogLike is the function I referred to as functionA.
This function calls another function called LaunchLogLikeForDivision.
This function calls one of two functions that are very similar and I refered as function1.
These are the following functions:
int CondLikeDown_NUC4_OpenACC (TreeNode *p, int division, int chain)
	int				c, h, i, j, k, shortCut, *lState=NULL, *rState=NULL;
	CLFlt			/**clL, *clR, *clP,*/ *pL, *pR/*, *tiPL, *tiPR*/;
	ModelInfo		*m;
    struct timeval start, stop;
    /*OpenACC auxiliary variables*/
    int numGammaCats=0, numChars=0/*, tiP_size=0, cl_size=0*/;
	m = &modelSettings[division];
	/* flip space so that we do not overwrite old cond likes */
	FlipCondLikeSpaceOACC (m, chain, p->index);
	/* find conditional likelihood pointers */
	clL = m->condLikes[m->condLikeIndex[chain][p->left->index ]];
	clR = m->condLikes[m->condLikeIndex[chain][p->right->index]];
	clP = m->condLikes[m->condLikeIndex[chain][p->index       ]];
	/* find transition probabilities */
	pL = m->tiProbs[m->tiProbsIndex[chain][p->left->index ]];
	pR = m->tiProbs[m->tiProbsIndex[chain][p->right->index]];
    /* find likelihoods of site patterns for left branch if terminal */
	shortCut = 0;
		case 0:
            //Count time
            gettimeofday(&start, NULL);
            numGammaCats=m->numGammaCats;
            numChars=m->numChars;
            /*tiP_size=16*numGammaCats*sizeof(CLFlt);
            cl_size=4*numChars*numGammaCats*sizeof(CLFlt);*/
	    tiPL = pL;
	    tiPR = pR;
            /*Check if we need memory allocation on the GPU*/
            if (firstTime==1)
                printf("firstTime -> TRUE\n");
            else
        #pragma acc data present(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats], clP[4*numChars*numGammaCats])
        #pragma acc update device(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats])
        #pragma acc kernels loop independent gang(numGammaCats)
	    for (k=0; k<numGammaCats; k++)
            #pragma acc loop independent gang(numChars/numGammaCats) vector(NTHREADS)/*vector(128)*/
            for (c=0; c<numChars; c++)
                #pragma acc loop independent vector(4) /*gang(numGammaCats), vector(128)*/
                for(i=0; i < 4; i++){
                    register int indice = k*numChars*4+c*4;
                    register int indice2 = k*16+i+4;
                    clP[indice+i]  =  (tiPL[indice2+AA]*clL[indice+A] + tiPL[indice2+AC]*clL[indice+C] + tiPL[indice2+AG]*clL[indice+G] + tiPL[indice2+AT]*clL[indice+T])*(tiPR[indice2+AA]*clR[indice+A] + tiPR[indice2+AC]*clR[indice+C] + tiPR[indice2+AG]*clR[indice+G] + tiPR[indice2+AT]*clR[indice+T]);
            #pragma acc update host(clP[4*numChars*numGammaCats])
            firstTime=0;
            printf("firstTime= %d", firstTime);
            gettimeofday(&stop,NULL);
            timersub(&stop, &start, &stop);
            timeradd(&accumulator, &stop, &accumulator);
    return NO_ERROR;
And:
int CondLikeRoot_NUC4_OpenACC (TreeNode *p, int division, int chain)
	int				a, c, h, i, j, k, shortCut, *lState=NULL, *rState=NULL, *aState=NULL;
	CLFlt			/**clL, *clR, *clP, *clA,*/ *pL, *pR, *pA/*, *tiPL, *tiPR, *tiPA*/;
	ModelInfo		*m;
    int numGammaCats=0, numChars=0;
	/* flip state of node so that we are not overwriting old cond likes */
    clA = m->condLikes[m->condLikeIndex[chain][p->anc->index  ]];
	/* find transition probabilities (or calculate instead) */
	pA = m->tiProbs[m->tiProbsIndex[chain][p->index       ]];
	shortCut = 4;
            //Count time
            tiPL = pL;
            tiPR = pR;
            tiPA = pA;
            #pragma acc data present(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats], tiPA[16*numGammaCats], clA[4*numChars*numGammaCats], clP[4*numChars*numGammaCats])
            #pragma acc update device(tiPL[16*numGammaCats], clL[4*numChars*numGammaCats], tiPR[16*numGammaCats], clR[4*numChars*numGammaCats], tiPA[16*numGammaCats], clA[4*numChars*numGammaCats])
                    for (i=0; i<4; i++) {
                        *(tiPA[indice2+AA]*clA[indice+A] + tiPA[indice2+AC]*clA[indice+C] + tiPA[indice2+AG]*clA[indice+G] + tiPA[indice2+AT]*clA[indice+T]);
	return NO_ERROR;
These two last functions are on the mbopenacc.c file, the main, LogLike and LaunchLogLikeForDivision are on a seperate file. The arrays *clL, *clR, *clP, *tiPL, *tiPR, *clA, *tiPA are global variables declared on the mbopenacc.h file.
What am I doing wrong?
Hi JPMN,
clp and the other pointers point into larger arrays. Since “present” just looks up where the device arrays are located by association with the host arrays, when you re-assign the pointer, they are no longer associated with the earlier “create”. Hence what needs to be created on, or copied to, the device are the “m->condLikes” and “m->tiProbs” arrays.
  • Mat
Hi mkcolg.
Thank you very much for your answer. So the problem here is that I can’t re-assing the pointer that I passed in the create clause.
Is there any way in OpenACC to tell the compiler to transfer an array of name X of the CPU to those smaller arrays on the GPU (clp, etc.)?
Or the solution is to pass the entire larger array at the beginning and then tell the compiler wich part of the array it’s going to access with the present clause? For example if I wanted to access only from position 30 to 40 I would do something like:
#pragma acc data present(tiProbs[30:40])
If this is the case then would I have to change the code on the CondLikeDown_NUC4_OpenACC and CondLikeRoot_NUC4_OpenACC? I mean these computations inside the for loop with these names would no longer work, right?
Would I have to change the names of clP and the other pointers?
Ok, let try and back up a bit since you’re not quite getting this.
At the time you use the data region in the main routine, you allocate memory on the device and also associate a host pointer (and it’s range) with the device pointer (and it’s range). When you use the present clause, the host pointer is used to determine which device pointer to use.
So what you need to do, is allocate the larger arrays on the device in the main data region. You then can assign the local host pointers (clp) to a location in the large arrays. You then would put “clp” in the present clause with it’s range. Now clp’s host pointer is used to find the same location of the copy of the large array on the device.
  • Mat
Ok, let’s see if I got it this time.
I need to allocate the larger arrays in the main part and I’ve got this:
/*Other code here*/
ModelInfo		*m = &modelSettings[0];
int tiProbs_x=m->numTiProbs, tiProbs_y=m->tiProbLength, condLikes_x=m->numCondLikes, condLikes_y=m->condLikeLength;
/*Other code here*/
tiProbs_gpu=m->tiProbs;
condLikes_gpu=m->condLikes;
#pragma acc data copyin(tiProbs_gpu[tiProbs_x][tiProbs_y]), copy(condLikes_gpu[condLikes_x][condLikes_y])
Then I should assign the clP and the other variables to parts of the larger arrays, so I do this:
	clL = condLikes_gpu[m->condLikeIndex[chain][p->left->index ]];
	clR = condLikes_gpu[m->condLikeIndex[chain][p->right->index]];
	clP = condLikes_gpu[m->condLikeIndex[chain][p->index       ]];
	pL = tiProbs_gpu[m->tiProbsIndex[chain][p->left->index ]];
	pR = tiProbs_gpu[m->tiProbsIndex[chain][p->right->index]];
And the two functions look like this:
   ModelInfo      *m;
   shortCut = 0;
      case 0:
            //Count time
       tiPL = pL;
       tiPR = pR;
            if (firstTime==1)
            else
            firstTime=0;
    return NO_ERROR;
And this:
   ModelInfo      *m;
  clA = condLikes_gpu[m->condLikeIndex[chain][p->anc->index  ]];
  pA = tiProbs_gpu[m->tiProbsIndex[chain][p->index       ]];
   shortCut = 4;
            //Count time
            tiPL = pL;
            tiPR = pR;
            tiPA = pA;
   return NO_ERROR;
However I still get the runtime error:
So what am I doing wrong or not getting this time?
By the way the variabes condLikes_gpu and tiProbs_gpu are global on the file mbopenacc.h.
You have the idea correct. My guess what’s happening here is that in the outer main data region, “tiProbs_gpu” and “condLikes_gpu” data are copies of the member arrays from the first element of the “modelSettings” array. However, in your routines, your using the arrays from “modelSettings[division]”. Unless “division” is zero, this is not the same data was copied in the data region.
What would work well here would be an unstructured data region. So instead of a well defined start and stop of the region, you could call some initialize routine in a loop and use data region for every struct element’s member arrays. Since only the addresses are associated, the name of the particular array would be irrelevant. However, this feature is still just a proposal in the OpenACC 2.0 specification (http://www.openacc.org/sites/default/files/Proposed%20Additions%20for%20OpenACC%202.pdf) so wont be implemented till later this year.
In the meantime, you may need to take the performance hit and copy the member arrays each time they are needed or reorganize your data into coalesced blocks (i.e. convert your array of structs to a struct of arrays.)
  • Mat
