I have a larger program that I am trying to convert so that the
computationally intensive part will run on an NVidia GPU using OpenACC.
However, I am running into trouble when running the program, as I am not getting the expected results. The part of the program to run on the GPU contains calls to subroutines, where
variables declared in a separate module are used. This seems to be creating issues. I have reduced the problem to the attached files test_link.zip (1.1 KB)
Please ignore the OpenMP directives. I tried to do the same thing with gcc 10.2 using OpenMP, but had other issues (and have sent a corresponding message to their mailing list).
I use Community Edition 19.10 and compile with:
pgfortran -O4 -acc -ta=tesla,cc35 -Minfo=all,mp,accel -Mcuda=cuda10.0 test_link.f90 common_vars.f90 parameters.f90 -o test_link
When I run the program I get for all elements in array IS2 the value 0, whereas I was expecting 24.
If I take out (or comment out) the subroutine TEST(), the corresponding interface and its call the result is indeed correct for all arrays.
Any hints on what could be going wrong?
Ioannis
