I’m facing problem while running a code of matrix multiplication using openacc on GPU.
Following is the execution trace from cuda-gdb. I couldn’t locate cuda_enter.c on my machine. My machine configuration is : GPU= Kepler GTX690 (K10), CUDA 5.0, Ubuntu11.10, Xeon 64bit processor.
Starting program: /home/arun/SW_vaibhav/openACC/mm
[Thread debugging using libthread_db enabled]
warning: Cuda API error detected: cuCtxAttach returned (0xc9)
[New Thread 0x7ffff5ea7700 (LWP 21379)]
[Context Create of context 0x766c60 on Device 0]
Program received signal SIGSEGV, Segmentation fault.
0x0000000000405172 in __pgi_uacc_cuda_enter (rversion=0x7fffffffdda8, objinfo=0x61d720, dindex=1) at cuda_enter.c:137
137 cuda_enter.c: No such file or directory.
in cuda_enter.c
(cuda-gdb) q
A debugging session is active.
Inferior 1 [process 21373] will be killed.
Thanks in Advance
Arun
