the following code does not work as expected, the min reduction returns 1e+10 as result value.
double minVal = 1.0e10;
#pragma acc parallel loop copyin(arr[0:n]) reduction(min:minVal)
for (int i=0; i<n; i++)
minVal = min(minVal, arr[i]);
The values in arr are all smaller than 1e+10.
The compilation info is:
pgc++ -acc -Minfo=accel test.cpp
main:
9, Generating copyin(arr[:n])
Accelerator kernel generated
9, Min reduction generated for minVal
11, #pragma acc loop gang, vector(128) /* blockIdx.x threadIdx.x */
9, Generating copy(minVal)
Generating Tesla code
const T1 & std::min<double>(const T1 &, const T1 &):
1, include "iostream"
39, include "ostream"
38, include "ios"
40, include "char_traits.h"
39, include "stl_algobase.h"
194, Generating implicit acc routine seq
I use PGC++ Version 15.4.
Am I doing something wrong or does the reduction simply not work?
Is there a workaround? (I tried it without the reduction clause to let the compiler detect the reduction automatically, but this doesn’t work)
Thank you for your help,
Marco
