Hi Mat,
Nice to see you online and very happy to see your reply.
I tried to recompile it by removing "reduction(+:tmp), however, the parallelization generation failed by reporting:
30, Generating present_or_copy(c(:,:))
Generating present_or_copyin(a(:,:))
Generating present_or_copyin(b(:,:))
31, Loop carried scalar dependence for ‘tmp’ at line 35
Scalar last value needed after loop for ‘tmp’ at line 40
Accelerator restriction: scalar variable live-out from loop: tmp
Accelerator scalar kernel generated
32, Loop carried scalar dependence for ‘tmp’ at line 35
33, Complex loop carried dependence of ‘c’ prevents parallelization
Loop carried dependence due to exposed use of ‘c(i1+1,i2+1)’ prevents parallelization
In addition, when I have reduction explicitly stated with kernels, I got many errors:
------ Rebuild All started: Project: 2ndOpenACC, Configuration: Debug x64 ------
Deleting intermediate and output files for project ‘2ndOpenACC’, configuration ‘Debug’
Compiling Project …
…\2ndOpenACCProgram.cuf
C:\Users.…\2ndOpenACCProgram.cuf(50) : warning W0093 : Type conversion of expression performed
0 inform, 2 warnings, 0 severes, 0 fatal for example1
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(100): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(100): error: expected a “)”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(98): error: attribute “global” does not apply here
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(98): error: attribute “launch_bounds” does not apply here
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(105): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(128): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(129): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(130): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(130): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(131): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(131): error: identifier “S108” is undefined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(132): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(132): error: a value of type “float *” cannot be used to initialize an entity of type “int”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(133): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(133): error: a value of type “float *” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(133): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(134): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(135): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(136): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(137): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(138): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(138): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(139): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(140): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(140): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(141): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(141): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(142): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(142): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(143): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(143): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(144): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(144): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(145): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(145): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(146): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(147): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(147): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(148): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(149): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(149): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(150): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(150): error: variable “rc4” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(151): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(152): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(152): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(152): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(153): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(153): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(154): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(154): error: variable “rc5” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(155): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(156): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(156): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(157): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(157): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(158): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(159): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(159): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(159): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(160): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(160): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(161): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(162): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(162): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(162): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(163): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(163): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(164): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(165): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(165): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(165): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(166): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(166): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(167): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(168): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(168): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(168): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(169): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(169): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(170): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(171): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(171): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(171): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(172): error: explicit type is missing (“int” assumed)
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(172): error: cannot overload functions distinguished by return type alone
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(173): error: expected a declaration
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(174): error: expected an identifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(174): error: a value of type “int” cannot be used to initialize an entity of type “int *”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(174): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(175): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(175): error: variable “b1” has already been defined
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(175): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(176): error: this declaration has no storage class or type specifier
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(176): error: expected a “;”
C:\Users.…\pgcudafor2a4C6bORi-hOB3.gpu(177): error: expected a declaration
96 errors detected in the compilation of “C:\Users.…\pgnvd2a2quIZC_nhXn.nv0”.
2ndOpenACC build failed.
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
It seems I got different compiling results as yours… Do you know why this happen?
Thanks and have a nice day,
Jingsen
