OpenACC on K20 - max data chunk size
I’m a graduating student involved in a performance analysis of a scientific application that I’m porting to OpenACC (I’m using PGI 14.1).
In some tests, I noticed that (thanks to NVPP) maximum chunk size of data transferred to device is 16 MB.
Is this an arch-dependent value? The device is a Kepler20s
Thanks in advance.
Paolo L.
Paolo,
The chunk size can be adjusted via an environment variable: PGI_ACC_BUFFERSIZE.
For example, if you wish to use a 32 MB buffer size, you could do the following in bash:
export PGI_ACC_BUFFERSIZE=32M
Hope this helps.
Best regards,
+chris
Thank you Chris, this is exactly what I need.
Have a nice day.
Paolo
